My vehicle does not work Emergency Assistance !!!
08.05.2020 19:06 # 1
ebulasey
Hello friends. My partner hill vehicle stopped automatically after 10 seconds of running yesterday. I tried to run it again, but it didn't work. I did not want to force too much so that the battery did not run out. If anyone has an idea that might cause it, I would appreciate it. Is there any possibility that it may have been fueled by cold?
08.05.2020 19:06 # 2
serdaralisan
Take a look at my friend's belts, if it is frozen, the circulation will not rotate and the belt will scrape off immediately, the car may stop freezing due to the cold, but did it have cold enough for the diesel to freeze? The diesel of the vehicle is frozen there
08.05.2020 19:06 # 3
ebulasey
We solved the problem. Since the amount of fuel decreased too much, it made air. When the injector relaxed and pressed the starter, he threw away the air inside and then worked. thank you to everyone interested ...
08.05.2020 19:06 # 4
baybaba
Get well soon, keep in mind when my partner is not working, how little fuel is doing,
I usually buy fuel when the light is on, do I need to buy it before the light is on,
08.05.2020 19:06 # 5
ebulasey
Thanks, I used it a bit more after the light went on, unfortunately, I think. I did not have the opportunity to buy fuel. I think I went 20-30 km after the light went on. It means you shouldn't push the limits too hard
08.05.2020 19:06 # 6
Efe-Pojo
Did it work when refueling, or did you just do what you said?
08.05.2020 19:06 # 7
ebulasey
I forgot to write it. Yes, we did some fuel supplements, but when it didn't work, it was possible to have air. And it worked when the injector relaxed and blew air.
08.05.2020 19:06 # 8
Efe-Pojo
The main problem was not that the air was taken in. As I thought from the beginning, the obvious fuel is over for you, it is a little bit to get air.
08.05.2020 19:06 # 9
ebulasey
If it were, my teacher would work when he put the fuel. We would not have used it for half an hour in the snow in the winter. Anyway, like Nasrettin teacher, find someone who fell on me :)
08.05.2020 19:06 # 10
qimyager
Do not wait for the light to come on, friends. You are using the dirty fuel in the warehouse.
