My vehicle does not work
08.05.2020 19:44 # 1
kirelli
Good night, my 307 1.6 gasoline car did not work when I got up in the morning after parking last night. I thought the battery was running out when I checked the battery, but the starter engine of the vehicle was running but I did not ignite it, the master said that it would be from the gas pump but it may be the same problem. Meanwhile, if you help working in one contact while the car is halfway down the ramp in the warehouse, I would appreciate it.
08.05.2020 19:44 # 2
vpro
If you measure the battery generally, you
The simplest reasons why it does not work is that if the pump is broken, it does it when the vehicle is running.
08.05.2020 19:44 # 3
baybaba
No problem in the immobilizer of the vehicle, have you tried with a spare key?
baybab to 2016-04-10 10:35:25
08.05.2020 19:44 # 4
Alicilik
Have the petrol system checked
08.05.2020 19:44 # 5
seiko35
I think the samandira may suffer, my brother may not detect the gas inside if he has a pain.
08.05.2020 19:44 # 6
peugeot murat
If the door lock button is blinking fast, it may have reset the bsi
08.05.2020 19:44 # 7
kirelli
I always use the vehicle with a spare key, they checked the samandira when replacing the gas pump. No problem appears.
08.05.2020 19:44 # 8
enyz
You turn the ignition, the lights are on, but there is not even a starter sound? there is no reaction.
the cable from the battery to the engine will look at it, there will be no problem
