My vehicle does not pass 3000 cycles error codes
08.05.2020 18:30 # 1
Ckmz17
friends, my vehicle is 140 000 at 1.4 hdi 206 models have stopped and started to turn off the malfunction once in the last month and realized that the vehicle has not gone 3000 cycles. I have looked at the error codes from the device p0183, p0230, p0231 are getting out What do they mean? Could you help me? I removed the error from the device, but again it burned, the vehicle was completely removed from the maintenance, and then it started to do it. I expect cvp from friends who have knowledge on this subject or friends who have experience.
08.05.2020 18:30 # 2
saruhan
Dude, clean or replace the flow meter.
08.05.2020 18:30 # 3
ahmet_bjk
I heard that the tachometer did not exceed a certain value when the air flow meter was defective, but this never happened when my vehicle's air flow meter was defective.
I don't think it will be from the air flow meter because the air flow meter fault code was P0104 if I don't remember correctly.
Didn't the person reading the error codes tell you the source of the errors?
08.05.2020 18:30 # 4
Ckmz17
I just said we should have gone to turn off the malfunction lamp.
P0183 Fuel Temperature Sensor Circuit A High Input Installation - Weak Connector Connections - Fuel Temperature Sensor - Engine Electronics
DTC P0230 Fuel Pump First Circuit Malfunction Program - Fuel Pump Relay - Engine Electronics
DTC P0231 Fuel Pump Second Circuit Short to Ground Short-Fuel Pump Relay - Engine Electronics
Are these things possible in any way, or they need to be replaced? Fuel pump failure?
08.05.2020 18:30 # 5
tprkozd
I had the same problem, I opened the issue in the same way, the problem was the flow meter was cleared and improved, so yours will probably have one more question. Does the vehicle do it when it is loaded when the vehicle is cold?
08.05.2020 18:30 # 6
Ckmz17
No problem when the vehicle starts first, it is normal, but when I go on a long road, do you know that it is related to the flow, it is certain that the codes come out when the fault lights up?
08.05.2020 18:30 # 7
saruhan
Man, delete the fault codes, clean or replace the flow meter. The meter usually gives an error after the vehicle warms up.
08.05.2020 18:30 # 8
Ckmz17
Thank you for your help, thank you. I will do what you call it is related to the flow meter. I will inform you positively or negatively.
08.05.2020 18:30 # 9
ahmetgulsen
my teacher, throwing the flow meter can be made from the turbo shaft, it may be broken from the exhaust institutions.
08.05.2020 18:30 # 10
tprkozd
I was doing it in my car when the car was cold.
