My vehicle does not exceed 140 km
08.05.2020 14:15 # 1
ask307
hi friends my car peugeot 307 1.4 hdi 2005 model 86000 km, also. My car has not exceeded 140 km for 4 months. I'm going up to 140 km with the 4th gear. I took it to the arkas peugeot service in Izmir, 1 day left, they finally changed a piece called the captor, they said okay. but the car was a little more relaxed at short distances. yesterday I got on the bus, although the road is downhill, the car likes this 150, it didn't go any more, the rpm hour was 4000. I know that I drove 190 km speed with this car.I am surprised what I'm going to do. this. I would appreciate if friends who come to this kind of problem help. Thank you from now.
08.05.2020 14:15 # 2
deniz_206
I have the same problem with the press pad.
08.05.2020 14:15 # 3
or 5-speed scroll from the second gear. 4th gear 140 km large speed If the engine or turbo is not able to reach this speed, the clutch shifts in every gear, but the car shouts, but as soon as I go, the transmission misses the socket, open the gearbox.
08.05.2020 14:15 # 4
t@lip
The engine does not shout, as it says the cycle does not exceed 3500, so I think the pressure pad is solid. Think well before you open the gearbox. Don't open it without making sure that the fault is the gearbox, because you can take the gearbox in your hand.
08.05.2020 14:15 # 5
deniz_206
These 307s are all about, gentlemen.
08.05.2020 14:15 # 6
trtolgi
Hi there. If there is a problem in the departure as much as I know, there should be a problem in the pressure pad.
08.05.2020 14:15 # 7
CIHANGIR_DONMEZ
we have 207 1.4 hindi in the first place, 170 of the buildod is now over 1560, the same driver on the same road noticed the vehicle in 63 thousand :(
08.05.2020 14:15 # 8
behzat
I think the pump is from the injector.
08.05.2020 14:15 # 9
hasimayaz
When the vehicle is stationary, what time does the cycle cut? Is there any fault light on?
08.05.2020 14:15 # 10
Long Beach
looks like diesel pump failure
08.05.2020 14:15 # 11
ask307
friends, I made an appointment tomorrow. said that they looked at the pump with the injectors bosh car in the service with the computer, he said no problem. the catalyst is empty, so the room is clean. I do not know the pressure pad or I do not know if it is the gearbox, I will tell you tomorrow. I already see the last cycle of 6000, I am 5000. I tried it today, 1st gear is 35, 2nd gear 72, 3rd gear 110, 4th gear 140 already loves 5th gear. I will leave tomorrow for 2 days and hopefully they will find the real fault this time.
08.05.2020 14:15 # 12
turbo27
turbo problem of my friend problem ... wasgate had to open at high speed, you will not have problems in early pain, departure and subsequent acceleration, but you will not get the performance you want at the last face, and your turbo is not fully efficient ..
08.05.2020 14:15 # 13
ozen80
I have the same problem with me, my car 307 1.6 HDI 110 HP goes up to 172 speeds in 4th gear, the speed remains at 3500 speeds in 5th gear, the speed is still the same 172. I can not reach the full speed .. If you found the caresi, would you write here ....
08.05.2020 14:15 # 14
STALLONE
it has nothing to do with the contactor, you better take it to an authorized service center
08.05.2020 14:15 # 15
STALLONE
heee does not show up in the turbo
08.05.2020 14:15 # 16
thekoch
Friends I have the same problem. Did you find a solution? What is the cause of the problem
My vehicle 307 hdi 1,4
08.05.2020 14:15 # 17
Carmania
I think it is either turbo-related or if there is a sensor measuring the air pressure above the intake monifolt.
08.05.2020 14:15 # 18
mod55
[QUOTE = deniz_206] these 307s are endless gentlemen. [/ QUOTE]
I agree.
08.05.2020 14:15 # 19
ask307
I think it has nothing to do with the turbo, if it is a turbo, the car does not go at lower times. I don't know the sensor in the manifold, what is his name?
08.05.2020 14:15 # 20
My brother had the same problem with me 1 month ago it was like he recovered but there was a slight pull from the traction. I changed the printing pad, it has improved.
Page : / 4
