My vehicle does not crank
08.05.2020 20:40 # 1
Mete2011
My friends vehicle 2005 model 206 x desing hdi battery is new but does not start. Battery power can be enough problem
08.05.2020 20:40 # 2
talip206
There are a few possibilities if the starter does not work.
1.Your key may not see a broken immobilizer chip. If there is a spare key, try with it.
2. Check fuses in the motor and inside.
3. The diesel pump may be faulty. Check engine from engine section while starting, does diesel come?
4. The crank sensor may be faulty. It is not recommended, but if it is working when it hits it, then it can come to mind if it is working without any trouble again.
5. The starter motor may be about to complete its life. Starts but cannot provide enough power.
6. Injector may be defective. Ariza comes out when it connects to the computer.
We cannot say anything clearly from here, but one has to look from simple to difficult one by one. talip206 2017-12-10 19:46:12
08.05.2020 20:40 # 3
Mete2011
I did it once when I hit it. Then, when it stops, the starter never starts.
08.05.2020 20:40 # 4
talip206
[QUOTE = Mete2011] I did it once when it hit it. Then, when it stops, the starter does not press. [/ QUOTE]
Then it is necessary to focus on the crank sensor or starter.
08.05.2020 20:40 # 5
Mete2011
Already the starter motor does not respond at all, I think the problem is this, I think we will look tomorrow now tsk for information
