my vehicle does not accelerate
08.05.2020 18:51 # 1
ergin1983
Hello friends
my car peugeot 206 hdi 2004 model. For example, when I press the throttle in 3rd gear, the tachometer rises, the car behaves as if it is idle, then starts to accelerate. what could be the reason for this
08.05.2020 18:51 # 2
omera
the same problem sometimes happens to me, I put it in 4th gear, the speed rises, the vehicle screams, but it does not accelerate, I put it back into neutral and fix it at 4. I think the gear doesn't find its place ...
08.05.2020 18:51 # 3
herry
the clutch may also be obsolete. needs to be looked after.
08.05.2020 18:51 # 4
ergin1983
does it cost a lot?
08.05.2020 18:51 # 5
herry
If the problem is debriefing, it does not cost much. most likely it is clutch, what you say is showing it, when you go, you press the gas, the car does not go, but the cycle goes up. This is the typical clearing problem. If it changes, it will be corrected, yet look for the service or master.
08.05.2020 18:51 # 6
ergin1983
thank you. I hope it is clutch :)
08.05.2020 18:51 # 7
samet206
If the pressure is missing, the speed increases, the speed does not increase, the problem ends with the change of the pressure pad, but do not neglect too much, it may be the case for you to stay on the road rather than visible.
08.05.2020 18:51 # 8
mrttkin
pressure seems to be a lining problem ... when throwing the car from 1st gear to 2, pull your foot off the clutch suddenly if there is a serious tremor, the pressure pad is definitely
