My tank got 64,560 liters of diesel, is there a mistake?
08.05.2020 18:00 # 1
oguzhan53
dear friends today I had an interesting event, there was about 1, 1.5 liters of diesel, the trip computer said it would go 115 km, I got filled to the tank, I took 64,560 liters of diesel. There is something wrong with my pump. If anyone comes to light on the subject, I would appreciate it. oguzhan53 2013-10-21 17:51:58
08.05.2020 18:00 # 2
samet2461
My master, your vehicle has a 60 liter tank. they have never been filled up to the throat at all, there is no other explanation. let me be clear that if my head was the same, I would be busy Smile
08.05.2020 18:00 # 3
[QUOTE = oguzhan53] dear friends today I had an interesting event in the warehouse there was about 1, 1.5 liters of diesel, the trip computer said it would go 115 km more, I got filled to the tank I got 64,560 liters of diesel, I was surprised. While Buying? There is something wrong with my pump. If anyone comes to light on the subject, I would appreciate it. [/ QUOTE]
I don't know the answer to your question, but I know that. If your vehicle is not a company vehicle, it is not good to fuller all the time. Diesel in your private vehicle max. half tank, min. it should be a quarter warehouse. As you go down to the quarter, you should buy diesel until it reaches the half again. Since the diesel is low, the fuel channels should not be damaged, and because the fuel is too much, the car should not burn more because it carries more weight.
08.05.2020 18:00 # 4
blinddark
my 307 1.4 hdi mine was too full, it took 65 liters full while on the long road, opetten writes 60 in the catalog but i officially filled it to overflow
08.05.2020 18:00 # 5
Serkan
65 lt came to me a lot, when we bought 308 zero, the seller warned that there was no diesel, the trip computer was also --- so it did not show the fuel, we filled it in the adjacent petrol immediately.
08.05.2020 18:00 # 6
oguzhan53
I did not make a full bottom on the display, it was in the middle of red 6 years, I always fill the tank at the same level, the max did not exceed 59 liters, 64 liters is more than me. Let's say what is the probability of making 64 liters if it fills up to the lid? oguzhan53 2013-10-21 20:59:38
08.05.2020 18:00 # 7
Serkan
If I was at your place, I would not leave without performing a fuel measurement test, even if they are not malicious, the calibration of the pumps is bad.
08.05.2020 18:00 # 8
halilefe
This is why I take it from the sheldle, I see my diesel, it presses my air, is it oil pressed, there is a transparent 5 cm part between the pump tip and the hose, it looks like a diesel, but there are 64 sister broths in this work.
08.05.2020 18:00 # 9
burglar08
Possible to have a game on the pump
08.05.2020 18:00 # 10
KIZILASLAN
While I was on holiday in Ramadan, we had the place where we bought diesel for the company. We made a 8 percent discount from there. I stopped the gun when I fired it 2 times and I did the last filling. The light was just on. I was 16 km.
08.05.2020 18:00 # 11
206 ersan
It is not good to fill the car to the throat, if there is evacuation, if I do not remember the misunderstanding, but if it is full up to the throat, the car cannot get 4 liters after the tank is full. I think that there is 1.5 lt or 2 lt diesel left, fulledim took 48 lt, your fuel station is either in good faith or if there is a problem with your devices, if you still have your receipt, go to search your right, repair your devices and fulfill a citizenship duty.
08.05.2020 18:00 # 12
oguzhan53
friends now which institution is legally controlling this station I am thinking of complaining about the incident there. I couldn't find someone to help me at the station. I need to find a way out in others without getting burnt.
08.05.2020 18:00 # 13
eeccaa
I do not think that the pump will install even if he puts 90 liters in that car. Similarly happened to me. The light was quite burned, I was going fast on the highway. My final average should be at least 6.5-7.0 tl / 100km. According to him, the computing computer range showed 55 km, if I'm not mistaken. When we saw the gas station, we stopped and filled it. The pump beat at 59.30 lt. I was amazed that it took more than 59 lt without any difficulty. It must be at least 3-4 liters inside. A little more could be added if he forced the pump. Of course, 60 lt of data, but in my opinion, when our tanks are filled to a small extent, it takes 64-65 lt.
To be sure; You can try to compare the last liter you took with the computer by filling the wiping diesel, resetting the trip computer, going for 100-150 km and filling the wipe again. If you see a difference again, I will investigate the complaints.
08.05.2020 18:00 # 14
ahmet_bjk
I think you should contact the service or Peugeot. Tell the situation, if they say nothing like that, then contact the complaint authorities.
The fuel tank volume written in the manual is perhaps the volume before the light turns on. In other words, 60 liter tank volume can be 67 liters in 7 liters.
08.05.2020 18:00 # 15
okan4037
In my gasoline car, whatever oil I use in my diesel car, it takes 67 69 65 liters. I am very nervous about this issue.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
