MY STOPS ARE NOT BURNING ... HELP
08.05.2020 14:56 # 1
Ozgur
I HAVE CHECKED FRIENDS INSURANCE BUT STURDY.
WHY DO YOU MAY NOT FLASH?
I DID MORE THAT TODAY. CAN IT HELP WITH INFORMATION?
08.05.2020 14:56 # 2
voodoo
I said it was a fuse but you did check it ... cable problem or socket may be dislodged ...
08.05.2020 14:56 # 3
bb1
the vehicle has a stop switch underneath the brake pedal, probably because of it.
08.05.2020 14:56 # 4
Muhammet CAKIR
It would be better if you first test whether there is electricity in the socket that enters the stop lamp and no lights are on, signal, reverse gear, parking?
08.05.2020 14:56 # 5
Ozgur
thank you guys all ..
normal parks or something but the lights do not light.
it happened to me for the first time and as you know it is very dangerous ..
the vehicle 206..the brake pedal means there is a stop sensor .. can i find it ?? it made sense.
because not from insurance
08.05.2020 14:56 # 6
Muhammet CAKIR
then he is doing what he says in his friend from the customer http://www.peugeotturkey.com/nasil_yapilir.asp?MakaleID=97
he explains in detail here :) easy come
08.05.2020 14:56 # 7
free led stop yours
08.05.2020 14:56 # 8
Ozgur
No, they are not led. I'm original .. :)
Thanks Çakır..I am a victim of tomorrow morning..but I wouldn't repair it.
uruk33 2010-11-02 22:59:07
08.05.2020 14:56 # 9
Muhammet CAKIR
[QUOTE = uruk33] they are not led. I am the original .. :)
[/ QUOTE] it doesn't matter what I think is, try to disassemble it, it will be thrown at the end of the piece, not only financially, but when they save you, try it yourself in such things :)
08.05.2020 14:56 # 10
furkan
maybe bsi makes it from the brain, if there is a short circuit, the kits itself is normal, but the lamp will not light up, disconnect the terminal of the battery for 10 seconds. wait then plug try it happened to me they couldn't do it for 5 hours 12 years old apprentice came up pole disconnected his head fixed problem solved BSI was renewing himself
08.05.2020 14:56 # 11
Ozgur
friends, thank you all.
the brake sensor is broken. I bought it from the service.
