My Sound System Annoys Me.
08.05.2020 17:45 # 1
KaBaDaYi
I have 2 poiners, anfim subwoofer in my car. The doors are original but they make a lot of scratch. My first job is tomorrow.
My other problem is that there is very little noise from 1 of the 2 poiner boats in the back, and there is no sound coming from the hoppers on the doors, while the boats may sound empty.
It would be nice if I came across an auto sound systemist that he knows in ADANA because I don't know anyone.
08.05.2020 17:45 # 2
Turgay_66
There is a setting that is less than one, more than the other, most of the tapes have a right-left setting, so you can adjust the sound so that it sounds more than right, more than the left or equal, and it may be less, because it has the same setting for the front and the back. I would say look at the tape settings so I can come :)
08.05.2020 17:45 # 3
Alicilik
I will help you if you are in Ankara, but I have nothing I can do to Adana.
I recommend the JBL 6508c.
If there is an oval in the back, you don't need to touch the 13cm league.
The ovals you use may also be a nuisance or a loosening in your installation.
Today we were looking at the cousin's 207, I said, let's examine the sound system. The 4-channel stereo amplifier officially oppressed.
They only saw 2 of them with 4 RCA outputs.
They connected the single unit without a fork and dropped the amp to two channels.
Bridge two channels and bass
they connected two ovals in the form of a bridge to the other two channels.
I witnessed that the Yaw oval speaker was connected in series. I'll get a hand on it as soon as possible.
08.05.2020 17:45 # 4
KaBaDaYi
[QUOTE = Alicilik] If you are in Ankara, I will help but there is nothing I can do to Adana.
I have looked at the JBL 6508c you said, now you have used the figures I think you know, I will probably get it. I do not understand from the sound system. I don't know how they pulled the installation.
I am a person who does not do the tapping work of construction tomorrow.
08.05.2020 17:45 # 5
KaBaDaYi
[QUOTE = Turgay_66] there is a setting that is less than one, more than the other, there is a setting that is in most tapes, you can adjust the right-left setting so that the sound sounds more than right, more than left or evenly, and so it may be less because it has the same setting for front and back. I think you should look at the tape settings so that it comes too much or comes from the front:) [/ QUOTE]
I hope so, or I will have to spend money on them.
08.05.2020 17:45 # 6
Turgay_66
it is likely that it is absurd to come less than the oval speaker on the back, and I have the same shape on the back and there are ovals on the doors, the ovals on the back are tied to the back doors, when someone sits in the back, I cut the back, the sound comes more from the front, the person you bought did something like that. :)
Turgay_66 2013-07-01 01:33:34
08.05.2020 17:45 # 7
KorhanAtaman
Sir, there is a sumer taxi around the mosque iboosman avenue mosque. There is already a sound systemist adjacent with a taxi.
08.05.2020 17:45 # 8
Aziz
[QUOTE = Turgay_66] is very likely because it is absurd to come less than the oval speaker in the back, I have the same shape in the back and there are the ovals on the doors, the back ovals are attached to the back doors, when someone sits in the back, it becomes too uncomfortable, I cut the back, the sound comes more from the front, you get may have done something like that :)
I have auto tuning this way, you can save +4 settings, one button transportation, the back ovals are completely silent while the little one sleeps on the long road, only the front speakers and tweeters work. I think you can reset the tape, if you do not understand, disconnect the fuse connection, reconnect it after a few seconds, return it to the factory settings and make your own settings :) I did it. The front sizzle may be due to this, because the sounds are overexposed due to the settings.
If the sizzle does not improve, do a cleaning first with an assistant such as an air gun to the front speakers :) If it does not, again, the worst 50 liras are stuck between :)
08.05.2020 17:45 # 9
Turgay_66
My teacher may also be this, if the tape is connected to the contact, that is, if the tape is closed when the contact is closed, it may be due to it, it was connected to the first contact, it made a sizzling when the sound turned on a little, it did not remove the electricity from the contact, so we connected it directly to the battery. Turgay_66 2013-07-01 12:49:07
08.05.2020 17:45 # 10
KaBaDaYi
these days I put the 16 cm mid team on the front door, the back kayak burst in hoperlor, they said to me that it was due to the wrong threat, I sent it to the warranty instead of zero 2 piooner boat sound 10 number 5 star was the only loss I did not want to give a lot of old tape clean 2nd hand or affordable and if you sell a handy tape, I would like.
08.05.2020 17:45 # 11
qqyyxx
[QUOTE = KaBaDaYi] these days I put the 16 cm mid team on the front door, the back kayak exploded in the hoperlor, they said it was due to the wrong threat. If I sell a hand-held or affordable and useful tape, I would like to.
I have a nice sony tape used for 1 month how much budget you have allocated for the tape. There is no usb input mp3 and aux. If you think I will give the link of the site on sale
08.05.2020 17:45 # 12
KaBaDaYi
[QUOTE = qqyyxx] [QUOTE = KaBaDaYi] they said that I had a 16 cm mid team on the front door, the back kayak exploded in the hopper, it was due to the wrong threat, I sent it to the guarantee instead of zero 2 piezer kayak sound 10 number 5 star was the only negative tape was very old tape too old tape I do not want to give money if I sell a clean 2nd hand or an affordable and useful tape.
Can you give me a link to the site?
