my signal is flashing very fast
08.05.2020 15:13 # 1
cakici9843
friends my right signal is flashing very fast. and click-to-click is at the same speed. so the normal signal is flashing 2 times a second while my right signal is flashing 4 times maybe more. Does anybody know the reason and solution?
08.05.2020 15:13 # 2
dukenukem82
You have a broken lamp
08.05.2020 15:13 # 3
cakici9843
[QUOTE = dukenukem82] there is a lamp that is breaking out [/ QUOTE]
are you serious? it had never occurred to me. if so my brother will look at it tomorrow.
08.05.2020 15:13 # 4
klemann
[QUOTE = cakici9843] [QUOTE = dukenukem82] you have a broken lamp replace [/ QUOTE]
are you serious? it had never occurred to me. if so my brother will look at it tomorrow. [/ QUOTE]
my vehicle did the same on the evening. the right signal was blinking too fast. The socket in the signal on the front was disconnected;)
08.05.2020 15:13 # 5
MemoTech
As your friend says, you have a burst bulb. One of the front or rear signal bulbs either does not break out or touch. If a single signal is lit (except the fender signal) it flashes much faster than usual.
08.05.2020 15:13 # 6
cakici9843
[QUOTE = klemann] [QUOTE = cakici9843] [QUOTE = dukenukem82] there is a broken lamp replace [/ QUOTE]
Thanks for your help, friends. bilemyior is here when you don't deal with it. The signal socket is in the headlight box. Is it necessary to completely remove the cover to install it?
08.05.2020 15:13 # 7
klemann
No teacher is located inside the bonnet.
08.05.2020 15:13 # 8
Keep your signal on, find out which one is not on fire. If it is ten, there is a small round plastic cover on the back of the headlight or even just behind the signal when the hood is on. When you turn it half a turn, then you see the lamp already. If it needs to be changed later, you will change it. Good luck with.
08.05.2020 15:13 # 9
cakici9843
[QUOTE = koliva] [QUOTE = cakici9843]
Thank you, Koliva, I already removed that cover, I know that bro.
08.05.2020 15:13 # 10
only_younus
One of the many questions of driver's license exams;)
08.05.2020 15:13 # 11
insomnia
one of the bulbs burst fast
second possibility, connect the car to the echocardiograph ...... ergolat other insurance, another ...... if you hear the rhythm, it goes on sale as muayyer :)))
08.05.2020 15:13 # 12
Muhammet CAKIR
Not only in light bulb explosion, I came to press all the signals I checked all of them are on fire.
08.05.2020 15:13 # 13
cakici9843
[QUOTE = Muhammet ÇAKIR] not only in light bulb explosion, it came to me, I checked all the signals I checked all of them are on fire, I look at the wires or something. if the bulbs are intact, you can try as [[QUOTE]
Let me take a look at the day, Mohammed brother, if there is no break, we will try it now ...
08.05.2020 15:13 # 14
Check Sockets Bidet Bulb May Be Burned or Loose.
08.05.2020 15:13 # 15
cakici9843
[QUOTE = albaydemircan] Check Sockets Bidet Bulb May Be Burned or Loose ... [/ QUOTE]
friends i fixed the problem this morning. As the colonel said, the socket was loose and I removed it, and the signal returned to normal instead. thanks to all of you ...
08.05.2020 15:13 # 16
the_beKKo
The fly is small, but it is nauseous, so we wear these little things on our heads. We love our car :)
I'm glad your problem is solved. :)
08.05.2020 15:13 # 17
cakici9843
[QUOTE = the_beKKo] The fly is small, but it is nauseous, so we wear these little things on our heads :) We love our car :)
YOU ARE RIGHT, SISTER IS A PROBLEM WHEN THE HUMAN SOLUTION IS NOT KNOWING THAT THE PROBLEM IS SMALL ...
08.05.2020 15:13 # 18
the_beKKo
[QUOTE = cakici9843] [QUOTE = the_beKKo] The fly is small, but it feels nauseous.
YOU ARE RIGHT, SISTER IS A PROBLEM IF THE PROBLEM IS SMALL, IT IS A PROBLEM WHEN I KNOW THE SOLUTION ... [/ QUOTE]
Exactly . :)
08.05.2020 15:13 # 19
I have a pao at the place of heat. I change the right ten signal bulbs 2 times. It does not go 1 week. There must be a malfunction in the vehicle. I left it now, when I make it right, it works fast :)))
08.05.2020 15:13 # 20
Ssedo
Let me try it tomorrow, let's see the subject in vain, I made pollution, patterned :)
