MY PROBLEMS with 307 sw
08.05.2020 20:34 # 1
eneserhat
Good markets, friends.
Can you give some advice about the problems of the old owner and me for the second hand 5000 (I bought it at 145)?
1- First of all, I want to take this to the bottom of the car in the trunk of the (Lovato brand) LPG tank (less than 10 years since it was installed in 2009). It was said that it is not safe to do this without putting extra protection on the underside of the car due to its structure. Does anyone have the LPG at the bottom of the car?
2- The former owner replaced the headlamp with a led bulb. I think he did not light enough at night. To get old type bulbs again or to buy more powerful led bulbs?
Would it be as solid as before? Though the old one was not strong enough that it was broken. :)
4-Glass opening keys are sometimes absurd in the glass controls on the left front door. That is, when I press the button to go down, it does not move first, it goes up next time, it goes down only next time. There is no such problem with the doors only when I do it from the control on the driver's side. I think the problem may be in the remote. Would you recommend an electrician on the European side of Istanbul?
5- A multimedia tape is installed in the vehicle, but the radio finds very little frequency even in a place like Istanbul. I could only find five or six. Is there a solution?
6-After performing detailed interior cleaning to clean the dirt of the car seat covers, the front passenger seat belt warning message and sound started to emerge. What can be done for this warning message and voice, although no one is on the sofa?
eneserhat 2017-09-17 11:56:40
08.05.2020 20:34 # 2
ben_erhan
Hello there,
1. I returned to the simit tank last week because my luggage was narrowed .. the process was just tank change, and the lpg filling nozzle was noticeable. I made it to tl .. sealing etc is not done anymore .. so i say more than 300 tl pay .. close to the inspection of the vehicle so that the documents are processed while the new tank is entered into the system ..
2. My advice is to return to the original whatever ..
3. Look at Letgo or something.
4. Do not go to the electrician for this .. unscrew it from there .. open inside. If it does not improve, including 45TL shipping on Aliexpresste.
5 ...
6 ...
These are my thoughts ..
08.05.2020 20:34 # 3
ggitaristt
Check the 5 antenna connections and cable, but probably the tape does not pull well.
A plug may have been removed under the 6 passenger seats or the seat belt may have gotten wet.
08.05.2020 20:34 # 4
Furkan979
I know that for the 4th problem, calibration can be done.
There is a sensor in the seat of the passenger seat belt.
LPG is a pretzel but it does not have protection, it can touch the wires on the zararida cables and we can cut the LPG indicator on the ten consoles, but it is not a problem for us. Furkan979 2017-09-18 01:31:03
08.05.2020 20:34 # 5
whisky
2- Halogen illuminates 4300 kelvin and 5000 kelvin halogens very well. I have a Philips Diamond vision at 5000k. I am very satisfied. the original was like a night light, it was not illuminating itself :)
5- You can have the tape antenna checked. Even the most rugged tapes find a lot of frequencies after all.
whiskey 2017-09-18 10:53:03
08.05.2020 20:34 # 6
eneserhat
Thank you all. I will consider your recommendations.
1- I have to clarify the subject of the Lpg tank before March. I started researching.
2- I had a nickel brand led headlight for better. He's a little better but not what I wanted. Maybe increasing it is not safe for oncoming drivers. So I will use it this way. If anyone wants to replace their original headlamp with a led in the future, I will trade it.
3- I order that piece for armrests.
4- The window controller will try the #ben_erhan brain recommendation first. "don't go to the electrician for this .. unscrew it from there .. open it inside. clean it in place, replace it .. you have 1 screw then you pull it out .. it has 2 wires with latch. push and pull out .. when you open it, you will understand how simple it is. including 45tl shipping on aliexpresste.
5- As you said tape, we were just about radio, let's not eat right. The video opens up, there is a bluetoth. But it is weak in radio. Maybe if I have the antenna checked, it will be fixed.
6- Seat Belt Error went the next day, which means it had to dry. Smile
Thank you so much.
08.05.2020 20:34 # 7
palet
1- Atiker has a thin bagel tank. If you buy this tank, you will not have a visa problem. If you get a thick depot, 3 people sit in the back seat and measure the distance between the depot and the ground. If this distance is not a certain length, the vehicle does not pass through the visa.
2nd-. Check the cylindrical metal part where the armrest black plastic passes. If it rotates in its place, the plastic you will wear will be broken. You must first fix this metal (without removing the seat) by welding the spot. The plastic you will attach to it will not be broken.
