My problems at 307:
08.05.2020 17:21 # 1
yasoo
Hi everyone ... I have 307 xs 1.6 3 doors 2002 model car .. When I bought the car since 2008, it was 80,000 and now it is 167,000. Thank goodness it did not hurt me at all. However, I have been scattered for the last 1 week .. I think the vehicle's electrical system has flown completely :) That is, the car's complete clock system works if it wants it (except for the speedometer). In other words, if you say the oil temperature and gasoline level indicator is not working, it is always at zero and sometimes it gets better when the tank is not full.
08.05.2020 17:21 # 2
yasoo
By the way, the vehicle does not have any LPG.
08.05.2020 17:21 # 3
inceyasar
Measure the battery
08.05.2020 17:21 # 4
yasoo
[QUOTE = inceyasar] Create the battery [/ QUOTE]
Battery on 1 month Varta brand :(
08.05.2020 17:21 # 5
inceyasar
If there is a problem in the charger, the battery may have run out. The battery in the charger is generating how many volts.
08.05.2020 17:21 # 6
yasoo
You are probably right, Yaşar .. Because something I have observed is increasing and decreasing when the headlight is short as if it is making a selector. 08 23:36:55
08.05.2020 17:21 # 7
I think there is a problem with the instrument panel. If you know how to remove it, the socket on the back may be loose. The worst is that the panel has expired. another panel can be installed in the service.
My temperature indicator is sometimes attached to the head.
08.05.2020 17:21 # 8
[QUOTE = Inceyasar] If there is a problem in the charging dynamo, the battery may have run out of battery. How many volts are produced in the charging dynamo. These kinds of problems are usually caused by the car's brain interference because of low electricity [
QUOTE]
Of course, this is also possible reason.
08.05.2020 17:21 # 9
yasoo
If the dynamo values are suitable ... I will measure the panel ... Thank you for your advice
08.05.2020 17:21 # 10
ismailkaya
I guess some money is stuck in your car, it is best to take it to the service.
08.05.2020 17:21 # 11
SDYMZ
Don't bother, don't call for a single death.
08.05.2020 17:21 # 12
Umut06
yes, it may be a charger.
The vehicle I bought a month ago was giving a brake error, high voltage was detected on the computer, and the coal of the dynamos has changed since then ...
I hope it's a simple problem .. . Member
08.05.2020 17:21 # 13
Ss307
the same thing happened to me came to charge the charging dynamo changed 120tl pieces kept 50 whistle this heat is over :)
