my problem is increasing.
08.05.2020 16:54 # 1
muratulug
Hello everyone again. I was worried that the light on my information screen did not turn off in a subject I opened. Now it turned out that the problem was not only from the information screen. friends with shortage of knowledge, let's solve it
08.05.2020 16:54 # 2
xpyhre
You have to go to an electrician master, my friend can't find the problem here. What are the problems? Yours is a simple process. & nbsp; Even the electrician's head does this work & nbsp; Solves.
08.05.2020 16:54 # 3
muratulug
thanks & nbsp; muratulug 2012-07-18 01:02:17
08.05.2020 16:54 # 4
fatihgg
There was an event in my press. When I took the car for the first time, when I changed the side flanges with LED bulbs, I wore a normal parking bulb. At the end of the end, I changed the led bulb and put on a normal parking bulb. Everything was normal. Meanwhile, the fault was the light bulb that did not light in the heat.
08.05.2020 16:54 # 5
boraaki
The LEDs feel even the slightest current. So they remain lit even if it is light. However, 1-2 minutes when the contact is closed. They must be completely extinguished in it.
