My Peugeot 3008 2015 problems
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
26.03.2022 18:18 # 1
ibanezjs1200
Hello. I have a Peugeot 3008 2015 model eat6 transmission bluehdi euro 6 engine allure package vehicle.
My first question is about auto glass. I'm just having a problem with the driver side. No problem with other windows. The one-touch closing feature does not work when I want to turn it off when the window is open, but it works when I want to turn it on when the window is closed. Does the key need to be changed for this issue ?
My other question is the underfoot storage compartments in the back. There is a problem with the left side cover. He probably had a vertical pressure on him. If a little load is placed on the lid, it collapses into it. No problem with the one on the right. I did some research and there have been people who have had this problem abroad as well. They made it more solid with 2 mm aluminum plate. If we want to buy the cover brand new, it will probably be very expensive. Have you experienced this problem? How did you solve it? I will share the images I found on the net.
26.03.2022 22:07 # 2
KaraKurba
The glass needs to be coded. Easy job. No parts needed. Here's how: press and hold the unlock button for 10 seconds when the window is fully open. Then let go and pull up and do not release the button for 10 seconds after the window is completely closed. This much. Is the problem fixed?
26.03.2022 23:55 # 3
ibanezjs1200
Unfortunately it did not fix.
28.03.2022 18:07 # 4
Well, sir, do all the windows close when I press the lock button on the remote? If it is closing, there is no coding problem. As you said, it could be because the battery is weak. when it comes to floor covers it makes more sense to cut a license plate.
28.03.2022 20:44 # 5
ibanezjs1200
Hello. My car's battery had just been changed, so it's been 9 months. But I don't know if it's because I don't use the car much. I've been using the tool for a while. I guess it's charged. I did the coding (I tried it as written in the booklet) but it didn't improve, but then after a little more I tried to see if it was working. He began work. Now it works flawlessly on all 4 windows.
When I press the lock button on the remote control for more than 2 seconds, all 4 windows close.
29.03.2022 14:38 # 6
Then there is no problem, sir. Probably, after not using the vehicle for a long time, the battery got weaker, since it was not charged, it means that there is no problem when you collect it now. good luck with it. I hope there will be no other problems.
01.04.2022 14:16 # 7
ibanezjs1200
Thank you. Thank you.
A friend of mine also had the plexiglass made for the rear passenger storage containers. Aluminum made more sense to me though.
