My Peugeot 206 vehicle stops while cruising.
16.08.2020 21:17 # 1
Shotgun
First of all, hello guys, peugeot 206 1.4 gasoline lpg I have a vehicle, but I don't use LPG, the vehicle is constantly getting on in gasoline, but as I mentioned in the title, my vehicle stops while cruising, I've had this problem 4-5 times since I bought it, I have had this problem.
17.08.2020 12:15 # 2
do throttle cleaning and adaptation. Check the air filter pipes in this one of the common problems of this problem in gasoline. In addition, if there is a problem in the lpg regulator, it causes gas leakage, which may be a problem in the manifold.
01.10.2020 15:12 # 3
mamuli
If the fault lamp lights up with the stop, it is the crankshaft sensor.
01.10.2020 15:23 # 4
Berkay Erdinc
Is it stalling when you release the accelerator or keep pressing the pedal. Accordingly, your malfunctions vary.
19.10.2020 23:52 # 5
umut1001
Hello. My vehicle stopped while I was going. There is no LPG. The car peugeot 206 2008 model automatic fever. I changed the crankshaft sensor 3 years ago and installed Delphi brand. I changed the petrol pump motor about 9 months ago. I did only about 25 thousand km) I looked solid. I stepped on the gas while climbing a slight slope in rainy weather and the car stopped, when there was traffic behind. I found a place to park from God. I will do a butterfly cleaning and try again. It lights up at slow speeds, with the stop text, it goes out when the vehicle accelerates. It had a wire left while it was playing, it broke today. There was some oil in the bellows pipe after the air filter, is it normal? hope10012020-10-19 23:56:11
