My Peugeot 206 Torsion Adventure |
| 08.05.2020 19:19 | # 1 |
seamad |
The cost I made for the torsion: Tornacı Osman 350 TL (including 2 miles) Snr brand torsion set 150 TL (two sides) DJ brand rear shock absorber 110 TL (two pieces) Sasic brand torsion bush 70 TL (2 pieces) torsion cap 50 TL (1 piece) disassembly and assembly 100 TL Total: 830 TL Newspaper from the torsion: ![]() It is not clear what they put out of this plastic torsion. ![]() The shaft is knurled, some places are filling and making the shaft with welding, but here it changes directly to avoid trouble ![]() buddha middle shaft ![]() |
| 08.05.2020 19:19 | # 2 |
This torsion adventure happens to many people who use 206 for a long time, thank you for the information. In general, the reason why people cool down from Peugeot is not cars, bad masters. |
| 08.05.2020 19:19 | # 3 |
Hodja, good luck to Gul, use Gul for your master's number.
| 08.05.2020 19:19 | # 4 |
teacher, where is this man's shop, I have some voices, but I can not get out of torsion.
| 08.05.2020 19:19 | # 5 |
seamad |
[QUOTE = sezar206] hodja where is this man's shop i have some voices but i cant get out of torsion. [/ QUOTE] Ankara Şaşmaz has a premium lathe phone in the industry. |
| 08.05.2020 19:19 | # 6 |
serky54 |
get well soon one day when I was on the road, I said that I pulled out of the plate 3 20 bmw selector, what happened to the side, the brother said, the back right wheel will come loose, I looked, I looked at the tight balance of the studs without problems, I went to the service, we saw that the problem of torsion occurs chronically within 5-10 years. There is no problem at the moment, I can press 170- 180 and enter the sweet corners safely. Even the vehicle is not driven because it hurts torsion when it is defective Greetings from Sakarya .. |
