My peugeot 206 does not eat gas
08.05.2020 20:58 # 1
emre_ozuymaz
CAN motor torque intermittent information / no signal error In PLANET 2000 device they could not delete this error code in the output service. Even if they did not understand. not emre_ozuy 2018-07-31 10:16:04
08.05.2020 20:58 # 2
Although my brother seems to have a problem in electronic or electrical parts, my guess is that engine ecu is also a problem.
08.05.2020 20:58 # 3
emre_ozuymaz
I understood, but in the peugeot's own program, the fault comes out in the transmission section
08.05.2020 20:58 # 4
Is the vehicle automatic or manual bro?
08.05.2020 20:58 # 5
cemalettinlevent
Is the accelerator pedal completely unresponsive
08.05.2020 20:58 # 6
emre_ozuymaz
automatic .. transmission was made, they said about the tribune did not come out of it. there is a reaction in the throttle but he faints on the slope shouts no performance
08.05.2020 20:58 # 7
Sir, the gearbox is controlled. and replace the brake sensor. You can have such troubles when the oil is put in the right oil too much or incomplete. float pressure values etc. Have you not seen or can not see because of this error.
08.05.2020 20:58 # 8
emre_ozuymaz
The gearbox is left, I suspect only the cellonoid and the valves. The vehicle gets even more bulky when it gets hot. If the brake switch is on, I don't think it will happen as soon as the stop lamp lights up. oil was also put according to your measurements
