My Peugeot 2001 model took water
08.05.2020 19:36 # 1
heinsing
Hi guys, first of all, I have a peugeot 206 car and I got into the car after the rain in the front passenger seat mat in the water.
08.05.2020 19:36 # 2
talip206
Usually, the wetness of the place you say does in the leakage from the heater core or connections. If you have antifreeze in your vehicle, it is easier to understand if the wetness is water or antifreeze. Does the vehicle reduce water? If it is not from the heater core, it may be from door wicks. The vehicle's rain drain holes may be clogged.
08.05.2020 19:36 # 3
heinsing
the vehicle does not decrease water door wicks glass wicks I checked everywhere while it was raining there was no wetness Can I open the drain holes or should I take it to the repair shop
08.05.2020 19:36 # 4
silverlion
Hello Heinsing,
Firstly, get well soon. The same happened in my front passenger section. It is useful to remove the door trim and check the underside of the white insulation. If removed or opened with silicone, the problem will be solved. There is a possibility that there are water drain holes on the underside of the doors, which may be clogged.
