My partner is stopping. ACİLLLL ....
11.10.2020 16:33 # 1
nazmiozcan3654
Hello guys, I just joined you. for about 4 years. I have a peugeot patner vehicle. I have a problem running my vehicle for about 15-20 days. I am running the vehicle. The car stalls as soon as I shift into reverse. He's getting better, then I hit the brakes, he's stop. The room is getting better. I'm touching the handbrake, it's stop again. In some way, when I remove the vehicle, each of these failures does not happen. When I take it to the electrical system, there is no malfunction in the pc. I showed 3 electricians. 3 also failed to see a breakdown. For the last few days, the handbrake lamp and stop lamp are blinking while on the road. It burns by itself, it goes out after a few seconds. When they pass, the battery lamp is on. I have the battery checked for a new charge. Waiting for your valuable comments and information. Thanks in advance. In the meantime, I joined you from İZMİR DEN.
11.10.2020 20:50 # 2
talip206
Looks like there's a leak somewhere. Check if there are non-original tape lights etc. Measure the charger while it is in motion. High or Low Voltage May Cause Problem. Handbrake warning and stop text can also give a warning when the brake fluid is low. But this usually gives when climbing uphill. You need to be able to distinguish it well.
12.10.2020 14:26 # 3
exactly, I agree with my teacher, professor
13.10.2020 23:32 # 4
ismailkaya
It can be caused by the catalyst sensors, especially when the lower oxygen sensor makes the engine stop, the momentary stop light and the oil lamp flashes.You need to observe that moment well, it stops when the vehicle is idle. 1. I said that it is sensors, the second is to look at all the hoses connected to the manifold and air hose.
