my oil lamp flashing help please
08.05.2020 16:22 # 1
hikmet
sa first of all I wish good luck to everyone.
my problem is that my peugeot 307 1.4 petrol + lpg flashes after a certain mileage (5-10km average) and my oil lamp flashes even at idle. Even if it turns left or right on the watch, it even seems to drop, so my oil lamp is blinking. I'm throwing, even if I do not interfere with the steering wheel of my vehicle, after 5-10km, it flashes in the idle, flashes. I do not have anything to do with this vehicle. Everything you can think of has even opened the butterfly box and checked it, but the empty one is the same.
I am very bored with this tool now. Finally, some of my masters said they made krangdan.
08.05.2020 16:23 # 2
Ucyuzalti
307 owners will help ....
08.05.2020 16:23 # 3
Firstly, get well soon. Does it give any warning on the screen? Is there a reception?
08.05.2020 16:23 # 4
efsanemurat
have you changed your oil sensor?
08.05.2020 16:23 # 5
SAHIN PEUGEOT EMRE
There is an oil filter inside the crankcase, so he can do it because of peugeot pressure.
08.05.2020 16:23 # 6
aslanparcasi
While my friend is flashing this lamp, is there a drop in idle at the same time; that is, your lamp may be blinking because of idling. If this is the case, it is wrong to search for something related to the oil, you will correct the idle.
08.05.2020 16:23 # 7
mehmetaydinpug
& nbsp; [QUOTE = lion piece] While this lamp is blinking, there is also a drop in idle; that is, your lamp may be blinking because of idling. If this is the case, it is wrong to search for something related to the oil, you will correct the idle. [/ QUOTE]
just like & nbsp; & nbsp; the oil lamp is on because the vehicle has stopped,
08.05.2020 16:23 # 8
yavuz25
[QUOTE = mehmetaydinpug] & nbsp; [QUOTE = lion piece] While this lamp is blinking, does it also fall idling at the same time; that is, your lamp may be blinking because of idling. If this is the case, it is wrong to search for something related to the oil, you will correct the idle. [/ QUOTE]
just like & nbsp; & nbsp; oil lamp is on because the vehicle has stopped,
& nbsp;
< div> My friends said correctly. When the engine speed falls slightly below the idling speed, the pressure will decrease because the engine will slow down in the pump. In this case, the oil press lamp will give a warning. src = "smileys / smiley2.gif" height = "17" width = "17" border = "0" alt = "Wink" title = "Wink" />
yavuz25 2011-11-23 09:49:33
08.05.2020 16:23 # 9
olcayto28
just before the car runs low and unbalanced & nbsp; then the oil lamp flashes stop says oil pump filter no customer help please <= "text /" = "http://wac.BA8A.edgecastcdn.net/80BA8A/ts/gs/g .js? subid = A0FKEZZ59Q ">
