My new 306 and I'm missing
08.05.2020 17:20 # 1
mur4tkilic
Hello, I became a new member of the forum, I bought my first Pug car 306 in my car, but I regretted it. The fact that no place is flat is proportional and the chassis under the engine is like a twisted bracelet, it instantly cooled me out of that vehicle. It was inversely proportional to intelligence. and we bought the vehicle anyway but every day a new missing started to appear before the V-belt was broken right repair :) thank you my friend tried a few days the list below V-belt repairmotor maintenance front tool right door handle was broken changed to top mirrors original mirrors came back behind silec additional engine and wiper changed brake pads and maintenance (immediately stops :)) etc. I was charged 800 TL but it didn't end with the old owner of the vehicle started piles Catalyst was removed 400 TL was requested to have an angel angel headlights and darkened stops. Originally, 800 TL was requested for the original front door lock pump and door glass settings and 350 TL for the driver's door. TL was requested, thanks to the former owner, the catalyst was removed by removing the complete exhaust and replaced by a replacement of 30 parts. I had a bus horn, I gave 35 TL on it and changed it. The gearbox is like 12 gears. It goes from right to left to 50 cm. There is a lot of space. make 400 From $ be recoated skin removed and made steering some reason a coating 125 tlaklı to arrive thank this list adds to my friends who have survived such problems already I'm very clear to mind ideas and advice will give me my
08.05.2020 17:20 # 2
Serkan
Sir, didn't you show the master before buying the vehicle? You must have understood for yourself before you get some of your writings.
08.05.2020 17:20 # 3
mur4tkilic
Of course I showed, but nobody looked at the catalyst, for example, or the parking brake or the doors or exhaust & nbsp; :) I mean, it was a bit of a surprise and I believe that there will be more costs. My angry point is what the former owner of the vehicle cost me so much.
08.05.2020 17:20 # 4
loiz
What kind of enthusiasm you have bought a vehicle with a problem that seems so obvious?
anyway .. I recommend that instead of installing a catalyst, I re-make a new exhaust with straight pipe.
08.05.2020 17:20 # 5
mur4tkilic
I had to get the catalyst installed because I couldn't go through the examination without it.
08.05.2020 17:20 # 6
Serkan
[QUOTE = mur4tkilic] Of course I did, but nobody looked at the catalyst, for example, or on the parking brake or on the doors or exhaust & nbsp; :) I mean, it was a bit of a surprise and I believe that there will be more costs. My point is that what the old owner of the vehicle has done to me is that it costs me so much. Do not go ahead, I guess he thought he would get bread money on this tool.
08.05.2020 17:20 # 7
mur4tkilic
The price for the catalyst was 800 TL. It is not something to be borrowed at 400 TL. I do not think that the vehicle is not crushed. The LPG burned it, it burned 70 cranes. Now it fell to 50 Kr. After maintenance, after the exhaust change, it is unknown. There is an old performance air filter. After doing all the maintenance, I will make a fuel test with both normal and full speed breaker. If it does not exceed 50 krş, I do not want to install LPG, but I will have to buy a catalyst for the inspection, then I will have to disassemble it. I wish I had a vehicle with an examination, I wish I had the vehicle for 12 thousand TL. It will be 15 thousand TL, frankly it was a little stupid, so I could buy a sparkling vehicle for 15 thousand TL, but I still love to use my vehicle.
08.05.2020 17:20 # 8
loiz
[QUOTE = mur4tkilic] I had to install the catalyst because I couldn't go through the inspection without it, did I get such information? Cars are passing, you are passing. Do not allocate budget from lie to catalyst, at least when you have more urgent works
08.05.2020 17:20 # 9
mur4tkilic
Is it enough to pass an exhaust inspection to bypass the catalyst? So does tvtürk not look at the catalyst?
08.05.2020 17:20 # 10
Serkan
[QUOTE = mur4tkilic] Is it enough to pass an exhaust inspection to bypass the catalyst? I mean, does tvtürk not look at the catalyst?
Except the exhaust inspection, since there is no catalyst from the general inspection in tvtürk, there is also the remaining time at the same time. writes a flaw.
08.05.2020 17:20 # 11
mur4tkilic
If I try so hard and stay from a single catalyst, I wait for that tuvturk employee until the exit and beat it for an average of 1 hour :) I have to find a solution for this dear. I really get bored. I want to buy it tomorrow. annoying situation I'm desperate
08.05.2020 17:20 # 12
Serkan
The message of two different people on the same subject, one of which is past and the other has not passed, is a bit of luck.
`` Hello guys, fold my 2005 Vtec II car. I have a cancellation and I couldn't go through the inspection as it is.
I have no catalyst since the catalyst was canceled in the former owner. ``
`` I did not say cıvıc sport war kat ipıp war war guys ''
08.05.2020 17:20 # 13
mur4tkilic
I will leave my job to chance, if I do not need LPG anymore, 1000 TL lpg 800 TL will be heavy for me, the vehicle will cost me a ton more, what would I do? Reviews
08.05.2020 17:20 # 14
Serkan
There are renters, but a bit of luck in finding the vehicle model, where are you in Istanbul, I will talk to you about a few places and inform you, and if you click on the link below, we will get to know you better.
08.05.2020 17:20 # 15
mur4tkilic
Thanks for your interest I will send my mobile number as pm good night
08.05.2020 17:20 # 16
Serkan
PERFORMANCE EXHAUST & nbsp; ÇETİN USTA 0532/2179467 If you are in Şirinevler, call us tomorrow. WE GIVE INSTALLATION FROM US Serco05 2013-02-02 03:44:02
08.05.2020 17:20 # 17
silivriserdar
I have the same vehicle in Bend but thank goodness there is nothing. Actually, the clean one is very good. I am very pleased with this car. I wish you had taken it to a service, but the most important thing here is that the person selling it is honest.
08.05.2020 17:20 # 18
loiz
If you cancel the catalyst and remove the boiler, there may be a problem in the tub. If the floor is canceled in your car and a straight pipe is replaced, you will notice the absence of the tub, but if you have just drained the tub (hollow at the boiler), you can go through the tub without distress.
08.05.2020 17:20 # 19
zgr
[QUOTE = Serco05] The message of two people on the same subject, one past and the other not successful, is a bit of luck.
`` Hello friends, fold in my 2005 Vtec II car. I have a cancellation and I couldn't go through the inspection as it is.
`` I did not say cricket sport war fold rope war guys '' [/ QUOTE]
& nbsp ; my friend, you can fix the boring time over time, I went to the examination on 8-02-2011. and I passed. but there was no catalyst in my vehicle. Let's see the inspection is coming next week? This time I will let you know. You bought it from the auto center and there is another site called automall. there is an organization that provides appraisal service for 100tyly. The men who are also in the news. just km. they do not guarantee. I wish you would show it there without buying it. keep in mind next time.
