MY NAZLI 307
08.05.2020 18:11 # 1
uslu5421
Guys, I have a 2005 model 307 look, I wrote messages before.
1-my clutch pedal was falling, the lower center and the bow changed, it was falling again, it was a dangerous situation, I tell the master how he said something Disapprove Is there anything happening to you?
2-For a week, the brake fluid has been decreasing as if I couldn't see it when I looked at the box, it was a very thin transparent oil, I put it in half of a box, but as if it did not appear, it is a very thin oil, but the brakes are well kept. There is no oil etc. discharge at the bottom.
3- Is this always normal at 90? Sometimes it is 80-85. It should be between 90-100 in gasoline engines. If the temperature is low, it means that there is a problem.
4-PLEASE RECOMMEND A MASTER TOGETHER WITH A HANDICATED VIRTUAL TOK, WHICH MAY BE INTERESTED IN 307 MINES OR Z EVERYTHING IN THE HIGHLIGHTS OF ANATOLIAN SIDE I WILL RELIABLE FOR GOOD REASON.
thanks in advance for your answers
08.05.2020 18:11 # 2
What I can say about overheating is that it is normal for all of us to be 90 in their vehicles. Don't worry about the heat. When it comes to brake fluid, if you press the car where it stops, the brake will inflate even if the car is running but I do not have any information outside of it.
08.05.2020 18:11 # 3
uslu5421
Thank you very much, the subject of fever was uneasy, I have no experience with the car since it was the first 307 m, and I was relieved.
08.05.2020 18:11 # 4
307 may make mistakes that will bother you for a moment, but they are all tiny things. No need to bother.
