My LPG Vehicle is Burning a Lot of Gasoline !!! |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 17:19 | # 1 |
| 08.05.2020 17:19 | # 2 |
date ..
| 08.05.2020 17:19 | # 3 |
friends, is there anybody with information?
| 08.05.2020 17:19 | # 4 |
Hodja, how do you measure the consumption of gasoline until you run out of gas, or you calculate the visibility to the gauge, if you calculate from the gauge and the psa module is not installed, the fuel gauge falls on the lpg but the fuel in the tank does not decrease |
| 08.05.2020 17:19 | # 5 |
My teacher, I fill the tank in LPG, I throw gas at 30 TL, I usually travel 300 km on average and the fuel light is on with the warning on the road computer and the pointer indicates that the tank is empty.
| 08.05.2020 17:19 | # 6 |
My teacher thinks that if your vehicle does not have a psa module installed, the vehicle is on the gasoline and the indicator is falling, you must either fill the tank completely or empty it for correct measurement. |
| 08.05.2020 17:19 | # 7 |
My friend is normal to spend 60 TL gasoline in the winter ... My peugeot is burning the same in my 206 lpg car right now, but I am not complaining. If you think that you go about 1.5-2 km with gasoline, you can spend 20-25 TL gasoline in 1 week.
| 08.05.2020 17:19 | # 8 |
teacher, my friend also has a lpg vehicle, believe that 50 tl of gasoline is going to him for 3-4 months.
| 08.05.2020 17:19 | # 9 |
Teacher, fill the tank until it throws a gun, note the km, fill it again after 1 month. 50 days is how many days it will be over The first method is healthier, the second method is likely to damage the gas pump. |
| 08.05.2020 17:19 | # 10 |
Thank you for your help, thank you guys ..
