My LPG vehicle burns a lot of gas |
| 08.05.2020 20:45 | # 1 |
| 08.05.2020 20:45 | # 2 |
Hello sir; While in LPG, gasoline does not burn, only the gasoline needle falls. The best way to test this is to check how much fuel the fulle gets to the fulle again after a few days of gasoline fulle.
| 08.05.2020 20:45 | # 3 |
My teacher takes a long time to switch to gas as the weather is cold. The engine burns a little too much in it is cold. If I fuse gas three times a month, I throw 50 TL in gas once. In winter, when the engine is cold, check out 1 liter of gasoline per contact.
| 08.05.2020 20:45 | # 4 |
Exactly, my teacher tells the truth. From gas to gas, Heleki engine is cold and it is very difficult in the morning. Since it works with gasoline, I do not want to close it. I run the vehicle at idle. |
| 08.05.2020 20:45 | # 5 |
I filled the tank in July, there is still half a tank of gasoline. If you use it with LPG, if you do not switch to gasoline, you won't run out of gas. the indicator is falling off on its own. There is a problem in the lpg system even if gasoline is really running out. it was a friend of mine was consuming both lpg and gasoline, whatever. then had it repaired. It wasn't a very costly thing
| 08.05.2020 20:45 | # 6 |
Is the needle rising again when my teacher runs again
| 08.05.2020 20:45 | # 7 |
It's not that late, but even if it does, does it burn
| 08.05.2020 20:45 | # 8 |
Teacher, I did not know him either. Everyone says that the needle is falling. I guess I have to test and test
