My lighting projects.
08.05.2020 17:53 # 1
With the permission of my Lord, I will share the results pictures and videos under this topic with the approval of our admin friend about sharing my works with you, with the approval of our admin friend. I will continue to share my work as a subject in the required section. You can examine the illustrated details of all my work on the forum of nightici.com. In 2009, what I did to my first vehicle, which my Lord gave me, has caused me to be devoted to these works. Now, I have to comply with it. .Playing daytime running light was installed, I changed the leds inside it and made it possible to call the daytime running light. For the 2000 model Honda Civic.93 model Şahin, the led was stop.Amateur. oktay toker2014-03-01 04:52:55
08.05.2020 17:53 # 2
Indicator LEDs of Focus F1 vehicles.93 Mercedes C20091 Mazda 323 f hb.2001 Astra.97 golf.Mens mounts.Focus F1Focus F2.5 lens and power led signal. 2011 Focus F2.5 lens, led american park.Focus F2 Angel ring jet black lens headlight.spider black Focus F2 lens headlight.Fusion Double color half angel darkened lens headlight.Honda motor bi-xenon lens headlight.oktay toker2014-03-01 05:07:34
08.05.2020 17:53 # 3
2001 Astra Valeo bi-xenon lens work.Focus F2 dual color angel ring.Audi A3 double color angel.Mondeo Mk3 bi-xenon lens modifications to original lens headlightsLinea Bi-xenon lens and orange angel ring modification.Modification of junian type headlights.Hella lens Fitting, improving the leds of the rings and modifying them by installing half watt power leds on 4 groups of leds. Fiesta sonar headlight modification by installing orange leds on the rings, mounting power leds to the signal. Valeo Bi-xenon lens modification. Golf 4 Hella bi-xenon, High beam power led, Power led signal, power led daytime running light. Citroen C4 series Ultra light multi-purpose daytime running light. C-max daytime running light. Space lighting with Power leds. Focus 2.5 led mirror signal. Focus 2.5 Power led signal, power led Brake, parking stop operation. oktay toker2014-03-01 05:13:06
08.05.2020 17:53 # 4
Shift knob led work. Some videos about the works. The results of the work for the Toyota Land Cruiser VX100. This is the result of the 8 daytime running lights I made in my parking section. oktay toker2014-03-01 05:24:25
08.05.2020 17:53 # 5
3.Stop original Hella production is a delightful production, but only the inner reflector. I removed the letters before drying out. There was a positive result in the middle. 6 red flux leds were used in this lighting. Adam Bey was not satisfied. I used 4 power LEDs. But I couldn't get a hamogenous light. I did not put the reflector in excessive light collection, I found it dangerous and tried to distribute 4 power leds. The reflector did not shine anyway. The reflector was exactly one piece for the full daytime running light. I did not take the reflector picture. this is so It was clear that he did not expect the result. 2006 Instead of the original lens, the Bosch bi-xenon lens and this time only I made the frame's own black. We put the D1s ballast bulb and the back of the lens as I said, I said the old type Hella would be easily replaced. I was very wrong. I started the work, I distributed the lens and it was a different structure. Thanks to Hella bi-xenon lens and the complete design with a good result, thanks to my Lord today we put on the headlights. The original Hella Square ballast and Osram D2s bulbs are in the original of the headlight. The first process was to expand the hat part of the original lens. I painted the front part of the lens beautifully with my touch pen. back to this part after mounting with line alignment I was completely insulated with Rtv silicone. I thought quite a bit for the main outer casing. First I thought that I would install this case without putting it, but it did not stick to me, it would not be long-lasting. Then I came to mind the pvc water pipes and bought them from the 2-layer thick types. It does not touch the metal, it is a well-assembled assembly for a complete insulation by inserting a half cm from the outside around the pole to the outer casing and screwing it from 2 sides and then complete it with Rtv silicon. The only flaw is that it is white. I plan to use this pvc pipe in other cover processes. Very good. We made our headlight adjustment on the wall. I did not buy the bulb holder for the new Hella due to lens change. I fixed the bulb with the screws by focusing. The bulb holder will be bought and installed as soon as possible. This is our ideal line for now. uzunlar.2 Did I get too close to the headlight? oktay toker2014-03-01 05:29:24
08.05.2020 17:53 # 6
2004 Passat Depo brand headlights were fitted with old type Hella bi-xenon lens and old lenses with high beam. Our friend chose Angel ring work from my daytime running style suggestions. I think ordinary saying. Power led work was done inside the signal and it was done inside the American park assembly. Here are some details with pictures. The first state and final version of the signal. American park. switching to park mode and filip flop-style image appears, I tried to picture and instantly capture the signal. Photobucket I took the height motors back in the headlights and the high beam lenses were a little more comfortable. I shot it at a distance of 1 meter between the vehicle and the wall. I had previously worked with mushroom leds and led strips on 15 lc monitors, but this time I had enough results by using smd5050 leds side by side and disassembling the fluorescent ones of the 17 lcd screens and using 2 leds in total. In terms of current, 1 ampere is more economical than fluorescent circuit. I do not have the chance to make it as in the original ones. It is as much as it is in the hand. It is lined up with the LEDs.
08.05.2020 17:53 # 7
Valeo new generation bi-xenon lens, Gen4 ballast Osram xenon bulb.It wore black and gray in the frame which is completely chrome.The lens cover exits from Mercedes. The view from the vehicle. Our wall picture. Although it does not give a nearly straight line like Bosch and Valeo Hella, the illumination illumination is extremely beautiful lenses. The halogens and bi-xenon are long. a full headlight was acquired. :( We put the headlights on the table. I was asked to open the expense, but there was nothing to do. Such work was present in haze sticky heat and so on. They tried to scrape the glue from the adhesive.Adative adjustment motor was removed and they tried to fix the adjustment of the lens by not fixing the fixing tab of the headlight bowl and fixing it with silicone. The part like the point was bent from the part that formed the upper line. The edge fixing places were also inclined. There was not much meaning to try to fix it. The hand prisoner lenses would change. Also it took water inside. And the hot silicon veins formed a hill. Due to its location, it was fixed with 2 screws with large butt top and was sutured well with the help of a screwdriver with the help of a silicon for supporting purposes. The image is a little bad, but it is necessary to feed the silicone. I fixed it in place as required. And the result. The lens hat is original. The inner hat was removed from the original lens and fixed to the new lens. 4300k but full halogen yellow I used very much. I had it done, but the right side of the bulb focus was not as smooth as the left side. The headlight setting was not complete for this reason. Then the D2s bulb and the inverter will be plugged in and set up again. Our wall pictures. The focus is on the top edge. Long with halogen. We have done the daytime running-out of the golf 4 headlamp, which I finished working with, and the result was fine. MVI_4604_zps8ae750ee.mp4 Video— tamircioktayy | Photobucket
08.05.2020 17:53 # 8
As our friend Kırşehir journey, he came to me on the road today.When we were giving the signal, we took the daytime headlight off by using an additional role and capacitor. > & nbsp;
< br>
Our video.
MVI_4580_zpsbb37b302.mp4 Video by tamircioktayy | Photobucket
08.05.2020 17:53 # 9
error
you have swallowed the led event, my teacher & nbsp;
first problem from me, fog is integrated in this headlight, & nbsp;
what is our chance to make this bixenon?
should we take out the fog light? We sprinkled angels in a couple of incidents, we got the buffers, if necessary, we put them in the bumper, ballasts and so on. What does it cost us? -height: 1.4; ">
good work.
08.05.2020 17:53 # 10
With 2 types of lenses, the new generation Valeo bi-xenon lens and the new generation Hella bi-xenon lens can be installed as a result of a work that requires a lot of work without disrupting the structure.
The important thing is to choose the lens cap and cut and assemble it according to the structure. If it is said that it is not a problem, it is possible to wear the desired lens easily.
08.05.2020 17:53 # 11
Gokhan Cetin
Malasallah, teacher, you enlightened us a lot "Thumbs
08.05.2020 17:53 # 12
kivanc
Maşşallah .. Have you ever worked for a 308 or may .. I want to make new modifications to my vehicle .. without exaggeration ..
08.05.2020 17:53 # 13
TuNeR_32
If you have a modification in the very successful peugeot 206 transparent headlight, I think I will have this work & nbsp;
08.05.2020 17:53 # 14
jiyanxese
I want to have my xenon car installed in my signature vehicle for a long time, but I have no knowledge and no skills, I don't know anyone who can make pistachio :(
08.05.2020 17:53 # 15
I have not been working on Peugeot vehicles yet. If it happens, I will share it as long as the management permits. 2013-08-23 01:29:59
08.05.2020 17:53 # 16
meto307
good work health & nbsp; good work, i have 2006 mod 307 vehicle, angel headlight can not be found, unfortunately we can make original headlights angel and I will be happy if you give information about it.
08.05.2020 17:53 # 17
tigerland
Studies have been professional to your health. In fact, I would like them to burn more vividly as the rings are a little weak in 206 sonar angel headlights :)
08.05.2020 17:53 # 18
It is quite possible for your problems to be resolved with the permission of my Lord.
08.05.2020 17:53 # 19
samet206
Have a nice work health in your hands ...
08.05.2020 17:53 # 20
yusufcaglarakarsu
Great work. Good health to your hands and your labor. I wish you a good job. Keep your way open.
Page : / 7
