My key is out of battery?
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 19:16 # 1
emresensoy307
friends, I locked the doors of my car remotely, but now I can't help wondering whether my battery is exhausted or is there insurance or something ... what should we do ..
08.05.2020 19:16 # 2
madblueblacksea
The battery does not run out of a sudden, the distance is usually shorter. It would be useful to disassemble the control and check for any contact. Even if there is no problem, you will remove the control as a preliminary preparation to replace the battery :)
08.05.2020 19:16 # 3
emresensoy307
I inserted the battery, put it in my act, there was an abnormality, if I did not have my service, if I had a look at the key ring, I did not understand it 1 hour ago I closed 1 hour later, I did not open the door.
08.05.2020 19:16 # 4
emresensoy307
guncel
08.05.2020 19:16 # 5
berk2309
Maybe the battery may be dead. If you have a battery in the same code, change it and try to give warning sometimes in 307.
08.05.2020 19:16 # 6
berk2309
There is something like a small tube inside the bde key container.
08.05.2020 19:16 # 7
emresensoy307
friends, I solved the problem, I contacted me halfway, long press, full contact key long pressed.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
