my help is urgent ....
08.05.2020 16:22 # 1
67rcep
slm friends today I made the mars dynamo of the vehicle.When I got it done, I bought the car from the master while starting the car while the sign on the indicator appeared on the display screen, PILE PLIP USAGEE text appeared on the screen, after I run the tool, it appears on the screen, but when I run the tool, it appears on the screen, but when I run, the tool appears on the screen. .saygı on ...
08.05.2020 16:22 # 2
Ucyuzalti
PLIP & nbsp; A word about BATTERY USED, probably something about battery & nbsp;
08.05.2020 16:22 # 3
Ucyuzalti
You can check it in french in turkish
http://www.sozluk.net/ceviri Reviews
08.05.2020 16:22 # 4
Your key controller warns of running out of battery.
08.05.2020 16:22 # 5
67rcep
I'm researching, let's see if you can tsklr ....
08.05.2020 16:22 # 6
67rcep
does it mean ins. that is a lot & nbsp; can i find it everywhere ....
08.05.2020 16:22 # 7
There are watchmakers, I took it there, the watchmaker changed ...
08.05.2020 16:22 # 8
67rcep
BUT THE DOORS ARE GOOD, COMFORTABLE AND CLOSE, I DID NOT UNDERSTAND. LET'S SEE WHAT WILL .... TSKLR FOR YOUR SHARE ....
08.05.2020 16:22 # 9
[QUOTE = 67rcep] BUT DOORS DOES GOOD COMFORTABLE CLOSE I DON'T UNDERSTAND IT. I'll try. It would be illogical to warn when it is already over. Because who used to do what?
Note: As per the forum rules, our articles should not be written in small letters "Embarrassed"
08.05.2020 16:22 # 10
METIN
THAT I HAVE THE SAME FAILURE, THANKS TO CHANGE THE BATTERY OF THE CONTROL AND TRY IT
08.05.2020 16:22 # 11
67rcep
Now you are right, today the battery of the controller is completely gone, the doors do not even open. For your sharing.
