my help !!!!
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Models
08.05.2020 15:48 # 1
efsanemurat
Hello friends, I will refer to your information on two issues
1. I parked the car three days ago, I came back after 5 minutes, turned the ignition, no sound, not starting, I waited a little, I waited again, tried as if nothing had happened yesterday everything was normal this morning worked in the first starter 30 minutes I went, I stopped five minutes later, there was no sound again I waited again, I did not press it, we tried a little bit, I did not understand why I did not understand why the battery would not work at all.
The second problem is that the temperature on the ramp is approaching the red line, that is 107 108 and when the temperature is at that border, when I hit a small pit, the temperature is playing miles, as if it was 90, it comes to 100, and as I shake, the mil comes back to red again. Until I wonder how normal my fan is not activated, because the service is distant, I called the wire, I said there is no problem until it does not come to red. They said up to 108 normal, sometimes it is not always in the 1st and 2nd gears, as if the car does not eat gas, then it suddenly rushes.
08.05.2020 15:48 # 2
beveta
Greetings get well 1 problem if I am not mistaken, the vehicle is picking up a chassis from the ignition system. stems from throat butterfly in the event of not eating ... it can make institution at a certain time 7 8 tl like something carburetor opener necessary to tighten ii forums ...
08.05.2020 15:48 # 3
efsanemurat
actual
08.05.2020 15:48 # 4
The same thing happened to me, I took it for two days, I took it to the master, and the man sat down and started the starter, he worked again, cut it again after two days. but it is highly probable.
08.05.2020 15:48 # 5
If the headlights slowly dim at night, the charcoal of the charger may be finished.
08.05.2020 15:48 # 6
efsanemurat
I will show it to a master tomorrow.
08.05.2020 15:48 # 7
goktug
I also had a similar problem. There was no click when I started. I took the starter coal was over, I changed it to 100 TL. Thank goodness bro. but I don't know if the problems are exactly the same. When I pressed, you said it didn't work, I hesitated that it worked 5 minutes later. Mine was working only by knocking, and after running it, it worked again even though I stopped it all day while the engine was hot, but it did not work in the morning when the engine was cold ...
08.05.2020 15:48 # 8
kaan__
the starter's coal is finished replace it 30-40 pounds don't give 2, I can't say anything for your problem
08.05.2020 15:48 # 9
cranberries26
mrb s .1. I had the same problem 15 days ago. I waited for 1 hour during the full vehicle inspection. I tried the inspection event. I asked the original valeo brand 700tl they said, then I bought the zero china goods and changed it to 125tl completely, no problem. In the 2nd problem, the possible circulation pump ... I hope it does not hold much ... it is easy: :))
