my hand brake does not hold
08.05.2020 18:55 # 1
daywalker61
I took it to the master, he said that the brake centers were stuck tightened, he said that it was necessary to remove and clean them and he took a price of 200 TL. I searched this brake center on the internet 2si 40 lira. Do you think these brake centers are the same thing that the master says, so if I buy 2 brake centers and give them 200 to the master, will I solve the problem?
08.05.2020 18:55 # 2
okaNStarss
intentional cylinders from the brake mechanism - linings and drums.
If you get 15 TL x 4 = 60 TL pads in the drum and discs lathe, only pads have hand brake mechanism at the back 45 back 35 front, if the back brake of the rear mechanic has set the fingernails, they will be able to make noise after a while. You have to change the brake ratchets of the backs of the teams 60 TL, so they cost 200 TL in total, if you want good maintenance :)
08.05.2020 18:55 # 3
daywalker61
Ben in front, disc in back
