My gasoline car sounds like diesel
08.05.2020 17:22 # 1
thejackal44
Hello. I am using a 2002 model peugeot 307 1.6. For about 2 months, although my vehicle is gasoline, & nbsp; sounds like diesel. By the way, there is no LPG. I asked 2 masters, one said: it could be oil, oil waited, oil took air, oil changed, he said. The second master said: The air filter is not fully seated. I'm confused too. In this forum, anybody has encountered similar problems or solved this job. thank you. km at 85000. He also eats a lot in fuel. thejackal44 2013-02-16 18:10:33
08.05.2020 17:22 # 2
Mehmet38
You can control the air filter by yourself.
08.05.2020 17:22 # 3
GokhaN
What is the oil, air filter? Smile
08.05.2020 17:22 # 4
GarajTurk
pushers hitting, Change engine oil.
08.05.2020 17:22 # 5
thejackal44
Thank you guys, but you all wrote something different. Of course, I am waiting for your technical support, respect
08.05.2020 17:22 # 6
emin15
We will be more helpful if you film and place exactly where the sound comes from.
08.05.2020 17:22 # 7
thejackal44
I shoot and add to the video as soon as possible
08.05.2020 17:22 # 8
thejackal44
[FLASH WIDTH = 250 HEIGHT = 250] http: // [/ FLASH]
08.05.2020 17:22 # 9
thejackal44
I shot the video, but I could not upload it to this forum, the closest master is 100 km from where I am, so I listened to a master from phone at noon on the phone, he said to me: "as far as I heard and as far as I told him on the phone, he was the thrusters, the valve thrusters," He said that it had to be dismantled to find out how many were broken and how many were intact. one of them was originally 25 TL. My dear friends, how much more will this voice handle me? I don't do a lot of miles but I can't go to the master this time. what can i do next. thanks
08.05.2020 17:22 # 10
thejackal44
who says nothing?
08.05.2020 17:22 # 11
Serkan
Sir, if you upload the video on youtube, you can put it in the forum.
08.05.2020 17:22 # 12
thejackal44
[TUBE] http://youtu.be/nuowzı2pk7y [/ TUBE]
dear friends, how long does this fault handle me.
08.05.2020 17:22 # 13
Serkan
Driving sound, teacher, did you change the oil?
08.05.2020 17:22 # 14
maestro
looks like a valve cup, does
do it all the time or does the engine run hot & nbsp; Did you delay the oil change or put thick oil in the car ?? If the problem is from the valve cups, as I said, the problem is just & nbsp; the loudness of the sound is no other harm as a result of my research. I have the same problem, if it is the problem and if you think to have it repaired, I suggest you change all of the cups. After a while, I changed 2 of the defective ones. After a while others started making sound, there is not much trouble in winter but especially in the heat, the sound increases. >
08.05.2020 17:22 # 15
thejackal44
Yes, I changed the oil in the authorized service 5 months ago. The sound has been around for about 2 months, I am not doing a lot of miles. The sound is constantly coming on the road when it first runs, so it is constantly. What do I have to do? In addition, the valve cup and valve pusher have different things. At least I found out that the valve tappet has 16. Thank you for your comments and help, regards.
08.05.2020 17:22 # 16
maestro
yes the same thing is the cup pusher ... brother as we said guess i know that if it is from this pusher, i know only the disturbing sound is the problem other than that & nbsp; I know that there is about 40 lira of them, according to my research from the forums, they said that when the oil pump malfunctions, it cannot pump the oil well and make noise.
08.05.2020 17:22 # 17
thejackal44
I understand, thank you guys, I will go to a good master again, we will get an idea, have it checked, if there is any, we will fix it.
08.05.2020 17:22 # 18
thejackal44
Waiting for the master
08.05.2020 17:22 # 19
thejackal44
Standing by
08.05.2020 17:22 # 20
emin15
If there is no loose spark plug, the sound comes from the valve thrust, does not fill the oil.
