My Fog Lights Came.
08.05.2020 20:23 # 1
doganatak
Friends fog lights came from peugeotmarket bought warehouse brand I have what I want to ask. I will remove the front bumper and cut off the fog slots.
1 - I will draw the fog from the car's installation except for the installation of the electricity that will work with a separate button, and which relay should I use?
2- What do you recommend as H1 bulb
3 - What kind of socket do you suggest for the fog connections?
08.05.2020 20:23 # 2
ggitaristt
Don't forget to put insurance.
ggitaristt 2017-06-01 01:27:04
08.05.2020 20:23 # 3
doganatak
[QUOTE = ggitaristt] Don't forget to put insurance.
does this relay have a name number etc ...?
08.05.2020 20:23 # 4
ggitaristt
They give it when they say relay in industry. 12V 10 (16) Amp standard relay. A little expensive for free ..
All of them are the same (big, small, glassy, illuminated ..). The relays of Tofaş are always from this. Don't forget the name, I don't know either ...
Correction: 87a is the place indicated by the arrow above .. I typed it in the wrong place ..
ggitaristt 2017-06-01 01:35:22
08.05.2020 20:23 # 5
doganatak
[QUOTE = ggitaristt] They give it when they say relay in industry. 12V 10 (16) Amp standard relay. A little expensive for free ..
Big smile If you say tofaş, okay, we are old toasters. Thumbs Up
08.05.2020 20:23 # 6
samet206
This is the scheme that I have drawn, applied and used. The fuses added for fog lights may seem unnecessary, but they are in the original system.
samet206 2017-06-01 01:44:56
08.05.2020 20:23 # 7
doganatak
[QUOTE = samet206] This is the scheme that I draw, apply and use. I recommend you use the relay 12V 30 amps.If you get all the materials and start work, it will be finished with pleasure. If there are no sockets on the vehicle, try to obtain them from the dispatchers. Fuses added for fog lights may seem unnecessary, but these are in the original system.
I think of the dispatcher, but the name of the dispatcher, the prices of the dispatcher never happen, I called foggy bumper in time, it was more expensive than zero bumper Confused
08.05.2020 20:23 # 8
samet206
It is so, but believe me, making a socket is very difficult. If there is a pert foggy 206 in the corner, you will cut the H1 sockets with the side cutter, they do not want much, so you are probably lucky if you have to look at the sockets that should be on the vehicle.
08.05.2020 20:23 # 9
doganatak
[QUOTE = samet206] It's like that, but believe it makes it very hard to make a socket. If there is a pert foggy 206 in the corner, you can cut the H1 sockets with the side chisel, they don't want much, so you're probably lucky if you need to look at the sockets on your vehicle.
Anyway, wherever I see a pert 206, I am going to get upset.
08.05.2020 20:23 # 10
Popomundo
Good luck, sir, I have a question, will you cut and assemble the existing bumper or buy a foggy bumper?
08.05.2020 20:23 # 11
most likely there are sockets in the vehicle. Our experienced friends provided information as a scheme. Be careful when cutting the bumper, then you have to get a foggy bumper. It would be nice if he finds something inside the link for the key.
08.05.2020 20:23 # 12
doganatak
[QUOTE = Popomundo] Good luck, sir, I have a question, will you cut and assemble the existing bumper or get a foggy bumper? [/ QUOTE]
Thanks I will cut my own front bumper ready bumper almicam I hope
08.05.2020 20:23 # 13
doganatak
[QUOTE = sonerkyl] there are probably sockets in the vehicle. Our experienced friends provided information as a scheme. Be careful when cutting the bumper, then you have to get a foggy bumper. It would be nice if he finds something inside the link for the key.
I will look at the sockets in my mind, I believe that I will cut the bumper properly. LOLBig smile I will find something like a key
08.05.2020 20:23 # 14
doganatak
I started bumper removal on Sunday. When I removed the bumper, I saw that the fog sockets were ready Thumbs Up Maybe I will add the photos I took while removing the bumper.
08.05.2020 20:23 # 15
samet206
You have found the fog light sockets, your eyes are illuminated. Depending on the availability of the sockets, you can connect them in com2000 control. It will be more original so you do not need to draw a separate line.
08.05.2020 20:23 # 16
doganatak
[QUOTE = samet206] You have found the fog light sockets, your eyes are bright.If you want the sockets are available, you can connect them on the com2000 control.
I do not need to buy a new arm if I do it from the arm, I use it with an ordinary button for now. Then there are nice buttons sold on aliexpreste and I get them from now
08.05.2020 20:23 # 17
No need to get a new arm, teacher pp2000 will be activated. If there is no possibility, it is not put on the role for the fog lamp in the fuse box.
08.05.2020 20:23 # 18
doganatak
[QUOTE = sonerkyl] No need to get a new arm, teacher pp2000 will be activated. If there is no possibility, it is not put on the role for the fog light in the fuse box again. [/ QUOTE]
In my arm, there was no bracelet for fog, I looked at the bottom of the fuse box, something like relay, etc ... nothing was seen
08.05.2020 20:23 # 19
Is your arm from the old one? like a square
peugeot 206 sinyal kolu ile ilgili görsel sonucu
08.05.2020 20:23 # 20
doganatak
[QUOTE = sonerkyl] Is your arm the old one? like a square
No, it's not like a square, mine is only for the rear fog. I will add a link below, I have pictures there.
doganatak 2017-06-13 18:28:56
Page : / 2
