My First Trial
Homepage » PEUGEOT MODIFIED PLATFORM » Virtual Modified
08.05.2020 16:50 # 1
reality59
rim, window film, and stickness. I want them to be like this. I think I have assembled it according to you. How do you think these rims are? height = "540" width = "720" border = "0" />
08.05.2020 16:50 # 2
Alicilik
17 "oz is nice to have used.
50mm spring set would be great.
1-2 glass window film for pleasure
and if possible, it would be great if you paint the black belts to the color of the vehicle.
Other than that, the calipers are red You can do it and definitely don't use nickel. You will have a simple and beautiful tool.
08.05.2020 16:50 # 3
reality59
* I think 15 "oz.
* number 2 window film. >
* I think the generations according to the color of the car.
08.05.2020 16:50 # 4
hsnsnl
If you think you want to wear 15 "I think there is no need to install it." I'm using 3,5cm. I'm glad .. paint the covers in dark red color;)
08.05.2020 16:50 # 5
Alicilik
[QUOTE = hsnsnl] I think there is no need to install 15 ". If I think there is a cover as the original rim, I think I would use the 5M original 57numara film as a film. I am using eibach in 3,5cm as a bow. I'm glad .. paint the covers in dark red color;) [/ QUOTE]
I absolutely agree. 15 "does not stop as in the picture. The original is 15", nonsense. It will be much better if you go to 16-17. If you think about 15, just change the wheels in photoshop, keep the tires.
3.5 einbach does your job if you don't want much.
08.05.2020 16:50 # 6
reality59
I just changed the wheels here, I didn't play with the tires. = "http://c1206.hizliresim.com/y/4/7ffgw.jpg" height = "1536" width = "2048" border = "0" />
This 3.5 spring version is fine.
The 5mm spring version I did not like this, but
here back 17" front 18 "should not be in the picture separately I did like this.
reality59 2012-06-04 02:15:46
08.05.2020 16:50 # 7
Alicilik
Of course there is some place in photoshop, but prefer to choose 16-17. 307 big vehicles will grin small rims.
There is a big difference between 3.5 and 5 5 does not reduce it. Turkey in the saddle that you swing the eccentricity Reviews
08.05.2020 16:50 # 8
reality59
Actually, I think that if I only make the wheels 17, I do not need any flatness because I did not flatten the first picture I gave. Do you have a design in your mind? can you say it would be better if you do that?
08.05.2020 16:50 # 9
sercinho
The heat will be 17 inches and 3.5 cm since the heat will be used.
08.05.2020 16:50 # 10
toga406
rims look so beautiful
08.05.2020 16:50 # 11
Alicilik
[QUOTE = sercinho] my attitude will be 17 inches and 3.5 cm since the heat will be used [/ QUOTE]
Sercan brother's advice is good. As he also mentioned his own vehicle. It has 17 "rc wheels and as far as I know it uses a 3.5cm kit. These will be very nice in the preliminary stage.
You will not change anything by wearing only 17". Because the radius between the end of the wheel and the end of the tire will not change. When using 185/65/15 you will use 205/55/16 or 205/50/17. There is not much difference with the eye. If you enlarge the rim without breaking the original size, you will have to cut the cheeks.
The aim of shortening the spring is to raise the connection part of the wheel. In this way, even if you are 14 ", the taxan will not be the same and the distance between the wheel and the hood will decrease.
08.05.2020 16:50 # 12
toga406
It is perfect according to the principle
08.05.2020 16:50 # 13
reality59
Do I have a problem in comfort if I wear a 3.5 kit?
Thank you all for your advice.
reality59 2012-06-04 14:47:22
08.05.2020 16:50 # 14
Alicilik
[QUOTE = reality59] Do I have a comfort problem if I wear a 3.5 kit?
You're welcome. There will be a slight drop in comfort. This may vary depending on the tire and rim you will use. You put the load on the car a bit more shock absorbers. The compression of the shock absorber and the compression of the spring is not one. The shock absorber is softer and more delicate.
The best explanation might be as follows. It is the air pressure within the resistance of the shock absorber. The springs are the flexibility of the metal. If you want to measure the response of the sudden pressure difference between the air and get a better understanding of iron.
front set of PeJo conditions in Turkey it is cheap compared to the poor and other brands. That's why people use 3.5-5-7cm bows very comfortably. If there was a possibility, we could find a quality coil over. Believe me, everything will be great.
If I go abroad (I think workand travel in my student life), it is definitely among the things I plan to buy. If I find heleki electronic, I wouldn't miss it at an affordable price.
08.05.2020 16:50 # 15
reality59
[QUOTE = ScHerZo] [QUOTE = reality59] If I wear a 3.5 kit, will I have a problem with comfort?
If I go abroad (I think workand travel in my student life), it is definitely among the things I plan to buy. If I find heleki electronic, I won't miss it at an affordable price.
frankly, you spoke very technically, I didn't understand much, but 3.5cm is ideal. ratio, I decided on 15 "oz racing rims, I plan to buy them at the first opportunity. http: // www. eliftuning.com/OZ-Racing-SUPERTURISMO-WRC-6x15-Inch-4x108_54736.html#0 & nbsp;
this is on the rim;) reality59 2012-06-05 02:41:34
08.05.2020 16:50 # 16
CEM1984
THERE IS 206S OF THE SAME VEHICLE WHITE SIDE CITALS BLACK WHITE VERY SLEEVE TEAM 3,5 YAY AND KARLIK BUMPER ATTACHMENT FROM 17 TO THE MOUNTED PASSENGER.
08.05.2020 16:50 # 17
Alicilik
[QUOTE = reality59]
frankly, you talked very technically, I did not understand much, but I decided on a 3.5cm ideal ratio, 15 "oz racing wheels, I plan to buy them at the first opportunity. I have financial difficulties as I am a student, this project may take a little bit of completion.) SUPERTURISMO-WRC-6x15-Inch-4x108_54736.html # 0 "target =" _ blank "rel =" nofollow "> http://www.eliftuning.com/OZ-Racing-SUPERTURISMO-WRC-6x15-Inch-4x108_54736.html # 0 & nbsp;
this on the rim;)
I'm looking for the wheel like crazy. The price is very expensive. If you have the opportunity, try to make 16-17 "as everyone says, or it makes no sense as long as you use 65 sidewall tires. You regret what you did. 17 "and if you use 3.5 bows and you say that it happened then. Of course the decision is yours. It would be better if you make your budget as you want without forcing it.
