My engine went from the cold :(
08.05.2020 18:59 # 1
Barbar_35
My vehicle froze to the tip of the car, we burned the UFO to the industry, burned it for 4-5 hours, we ran all the hoses, but we heard the sound of knocking from the engine :( the engine will be opened today.
What could be the problem?
08.05.2020 18:59 # 2
muro_60
Antifreeze was not there? Anything can happen.
08.05.2020 18:59 # 3
sezar206
I wish you had checked an antifreeze for the past.
08.05.2020 18:59 # 4
Barbar_35
I did not ask, I said I will check before coming home, but because of other problems, my mind is gone .. 20 pounds of negligence will lead to 2000 pounds :(
08.05.2020 18:59 # 5
KuzuX
Neglect neglect neglect .. We all do it. I hope there will be no major problems. When the engine is turned on, take care of it and change it.
08.05.2020 18:59 # 6
samet206
It was surprising that it had freezing in the radiator just because it was past ... So there was no antifreeze, it showed a lot of winter, and the cold itself was more than last years, but the antifreeze would not freeze a little.
samet206 2015-01-08 15:03:37
08.05.2020 18:59 # 7
Barbar_35
The man who I had just bought was the engine had it done in the service, the engine was pushed, there was nothing on the block. The cover we sent, they will change, I guess it will cost around 500-600 :(
08.05.2020 18:59 # 8
outlaw
[QUOTE = Barbar_35] The new man I bought already had the man in service, the stuck motor had nothing in the block. The cover we sent will be changed, I guess it will cost around 500-600 :( I am burnt, you will not burn [/ QUOTE]
IF 500-600 IS EXPENSED, BUT IT IS VERY LUCKY THAT YOU HAVE BEEN ... Wink
08.05.2020 18:59 # 9
baybaba
As I have seen, cars in Izmir always cause problems from the cold.
They don't get used to the cold weather like the people of Izmir, they get sick right away. Smile
08.05.2020 18:59 # 10
outlaw
WALLA I HAVE BEEN AFRAID TO WORK HOW DAY ..
I HAVE THE ANTIFREEZE OF THE TRUTH AND I STOP AT THE CLOSED PARKING BUT I ARE Feared Again ... ConfusedConfusedConfused
08.05.2020 18:59 # 11
Faruk
[QUOTE = outlaw] WALLA I HAVE BEEN AFRAID TO WORK HOW DAY ..
the weather in Ankara was -16 today.
I switched the ignition on and off 3 times. The last press started, the first sounds of the engine made me feel wet. Confused
It improved in 1 minute but I was not afraid that it wouldn't work either Smile
08.05.2020 18:59 # 12
Barbar_35
If Mars doesn't translate, let it go, or it will strip the timing like mine,
08.05.2020 18:59 # 13
yawruaslan
I don't know, I don't know if I have an antifreeze when I was in Istanbul when it was too cold. I haven't pressed what happens, what happens now, my car has not been running for a few days. I haven't pressed it in the starter. Do I have any problems if the weather gets a little warm?
08.05.2020 18:59 # 14
Barbar_35
You probably haven't frozen, but if it's frozen, it can block the block because it expands even if you don't
08.05.2020 18:59 # 15
outlaw
MY PREVIOUS WAS IN MY CAR THE BLOCK OF THE CAR IN THE FRONT OF THE DOOR WAS CRACKED BEFORE THE WEDDING AND THE COST OF ME ARGON CROSS RESOURCE WAS 3000 TL ...
08.05.2020 18:59 # 16
PARADOSK3327
get well friends
08.05.2020 18:59 # 17
yawruaslan
I came home when the Arkadsss got a little flat today, I put on my lion again, I looked at the radiator cover and opened the water, because the water was frozen, but I did not see any freezing, I made contact with the contact door 3-4 times, I pressed the lion to feed my lion, I did not press any marsa for 10-15 days. There wasn't even that turnover shake that 106 did, he didn't even have to play it :) tableAllah the evil eye did not change :) While he was working, I did not clean his right side, I did not give any gas after 15 minutes idling, I did not give any gas 15 minutes later, I took 2-3 rounds with the vehicle for 15 minutes. Then I parked the car for another 10 minutes, I run it at idle, then I realized that I was not exaggerated by the exhaust, so the smoke was so exaggerated that I did not see it before.
08.05.2020 18:59 # 18
Mesut48
[QUOTE = baybaba] As I have seen, cars in Izmir always cause problems from the cold, I guess.
Just hit how cool it would be, I said antifreeze I didn't check,
Yesterday circulation exploded gift 400 TL Smile
08.05.2020 18:59 # 19
Barbar_35
AngryAngryAngry goddamn car !!!
valves changed, valve stoned, circulation etc. etc changed,
The car was assembled, worked, but trembling, we did not deal with the cents for 2 hours, the last master said I sheared the valves Cry engine dismantling offffffffffff Wacko
08.05.2020 18:59 # 20
muro_60
no problem in your car bro brother
Page : / 2
