My emergency help traction problem ...
08.05.2020 19:22 # 1
Sertac
I have 106 model 106 xr vehicles. My vehicle is very cumbersome. 100u does not pass on straight road. He kicks off on the first departure in the morning. I made the setting for you. Spark plug spark plug cables have changed. There is no problem in my printing pad. The engine top cover gasket is new. I just replaced the oxygen sensor. But still my problem continues. I would be glad if you help..
08.05.2020 19:22 # 2
Sertac
Can't you help?
08.05.2020 19:22 # 3
Sertaç has not recovered, I'm still sorry. It is annoying people. Air filter box and hoses.
08.05.2020 19:22 # 4
Sertac
Air Filter exhaust checks were made, I guess others did not look. I will get crazy, I spent 1500 pounds of money, I changed the master, no use ..
08.05.2020 19:22 # 5
Sertac coach, your vehicle was LPG, did not control the LPG and petrol map sensors of the vehicle.
I also saw in the forum if you want to take a look at this link
http://forum.peugeotturkey.com/forum_posts.asp?tıd=18872
sonerkyl 2015-07-22 17:03:02
08.05.2020 19:22 # 6
Sertac
I noticed when I was playing by myself, when I pressed the accelerator pedal, the throat butterfly does not open 100%.
08.05.2020 19:22 # 7
Sertac
08.05.2020 19:22 # 8
Sertac
Does anyone have an idea?
08.05.2020 19:22 # 9
Well, I don't know that work, what are you doing in Sertac?
08.05.2020 19:22 # 10
Sertac
The problem continues. A recent master said he might have accidentally installed a diesel compatible transmission. I will be crazy now
08.05.2020 19:22 # 11
Do you think that yuh is diesel compatible? God give patience, what should I say my teacher, I hope he will come across a good master
08.05.2020 19:22 # 12
emre41
Does the computer show error? Open the hood of the deception hood, give the gas manually, look at the engine. Let's see if it works live. Usually, masters adjust the valve adjustment of the Peugeolts tight. In order not to make you smack. It should be 20-40. Have the fuel injectors checked. Check the gas pump pressure. Measure the engine compressor. I hope you solve the problem in thesis time.
08.05.2020 19:22 # 13
Sertac
I couldn't find someone to connect a computer, someone says the socket is not compatible, someone says it doesn't. It was the last care zeten computer. The engine runs great when the vehicle is idle. I press the gas, the vehicle falls on the cutter but does not go on the road. I made the valve adjustment 2 times. Injectors were checked. Even if there is a problem in the gas pump, the car is the same in gas. I did not create the engine compressor
