My emergency aid is not going, it is singing
08.05.2020 20:23 # 1
Vethekyunus
Good day, I just joined you. 1 week ago, I bought a 206 2001 automatic transmission 1.4 xr. My car does not eat gas now, it constantly stops. While going, he kicks, he makes gas, he makes lpg, It stops suddenly while standing. He runs and kicks all the time. Sometimes it doesn't go even though I press the gas. Sometimes it sounds pat when exhaust is going. I do not know what to do I do not know what to do with my car, which I bought with great enthusiasm. I'm waiting for your help.
08.05.2020 20:23 # 2
talip206
Coil may be malfunctioning. You'd better have the spark plug and coil checked.
Below is the link of the piece I mentioned. If your hand is prone, you can take it out yourself and check visually. Remove the rubber from the end after removing it.
If there are cases of oxidation etc., the coil is defective.
The place is in an easily visible place. You can get the original or beautiful in delphi brand products
http://www.peugeotmarket.com/peugeot-206-14-grı-soket-bobın-delphı,pr-207.html talip206 2017-06-01 04:01:07
08.05.2020 20:23 # 3
Vethekyunus
Thank you i will try
08.05.2020 20:23 # 4
First of all, welcome to us. As our claimant friend says, these problems are generally caused by coil and spark plug.
08.05.2020 20:23 # 5
Aleynaboyner
For the past, I had similar problems with me. Look at the ECU brain or the internal insurance brain. I took the car with the hammer. There is a possibility of damaging the transmission, so I have the 2000 model 1.4 xr.
08.05.2020 20:23 # 6
Vethekyunus
Thank you, I am in Kirikkal, so there is no service here, I will leave the industry today.
08.05.2020 20:23 # 7
talip206
[QUOTE = Vethekyunus] Thank you I am in kirikkal so there is no service here, I will leave it to the industry today [/ QUOTE]
If you write the result, it will be an idea for those who experience the same situation.
08.05.2020 20:23 # 8
Vethekyunus
Ok i will inform
08.05.2020 20:23 # 9
Vethekyunus
Spark plug and coil changed, gasoline stalled, gas continued. They asked if we wanted to adjust the lpg. Finally, we found a master, he made the setting improved, and there is no problem at lpg right now. I hope it never happens to anyone again
08.05.2020 20:23 # 10
I'm glad your problem is solved, hodja. Not every master is a master, they are immediately after the change of parts and whatever they are after.
08.05.2020 20:23 # 11
Vethekyunus
Just like that, my teacher said to me that the lpg master has nothing to do with this setting. He said, "Let's get a little bit of gasoline until it is over." We went to another master too thank god
