My emergency aid 206 cc
08.05.2020 20:20 # 1
A.iceloglu
Hello friends, my vehicle also has a problem of eating lifeless gas. Spark plugs and coil changed. The throttle was cleaned, the print pad also changed, but the problem still persists. The master said he might have missed the last sentence setting. There is no problem in its operation, but its performance has deteriorated. Is there anything like that ???
08.05.2020 20:20 # 2
First of all, welcome to us, there is no LPG in the vehicle, I think if it is due to it, if there is no gasoline, the problem may be related to the adjustment of the sentence, as the master said, but the pump of the gland - the map sensor - the gasoline filter - the injectors may also have problems. Connect the vehicle to the computer and see the fault code.
08.05.2020 20:20 # 3
A.iceloglu
Thank you, the vehicle has LPG but I use it on gasoline fuel pump injectors were looked at but the result is the same
08.05.2020 20:20 # 4
Is there any oil or water reduction in my teacher?
08.05.2020 20:20 # 5
A.iceloglu
No teacher
08.05.2020 20:20 # 6
Then have your teacher check the manifold for leaks in the air filter hoses etc. see if there is a leak catalyst may be clogged. When it is full, traction loss can occur. and clean the oxygen sensors.
08.05.2020 20:20 # 7
A.iceloglu
Sir, there is floor cancellation and open air filter in the vehicle.
08.05.2020 20:20 # 8
Well, the last thing that comes to my mind is the adjustment to the sentence of the vehicle, so everything that has to be done has actually been done. Sometimes other diagnostic devices may not see error codes.
08.05.2020 20:20 # 9
A.iceloglu
Ok teacher thank you for your attention
