My door creaking :(
08.05.2020 16:17 # 1
BurakGONULAL
"Wall" "C & nbsp; friends left behind my back door is harder than others, it hurts a little right now it started to show the same features on my right rear door, it started to squeak as a new feature, at some point, I have a sound like a serkuromus bio, there is no air, there is no air, dust, soil, etc. are these correct? How can I solve the problem?
08.05.2020 16:17 # 2
There is a screw towards the bottom, making it loosening over time.
My left back door started not opening from the outside, it is opening very hard sometimes I wonder why?
08.05.2020 16:17 # 3
BurakGONULAL
Pasha, can I do that screw tightening thing exactly where?
08.05.2020 16:17 # 4
If you do it, you will notice it when you open and close it. If you already pay attention, there is no clear photo if it is loose. 573 / 19537002.jpg / "target =" _ blank "rel =" nofollow ">
Uploaded with ImageShack.us
Reviews
08.05.2020 16:17 # 5
BurakGONULAL
Okay, I will look at it in the first heat in the morning.
08.05.2020 16:17 # 6
You're welcome, I hope it will be useful. Other links also relieve the bass vd40.
08.05.2020 16:17 # 7
BurakGONULAL
[QUOTE = HuseyinTurk] Thank you, I hope it will be useful. It is a bit more comfortable to press vd40 on other connections.
08.05.2020 16:17 # 8
There is a rust remover, lubricant spray called vd40, you can find it even in big markets & nbsp;
08.05.2020 16:17 # 9
BurakGONULAL
Just for you to creak, do you get bored of it in the morning you would dip the screw in the car in the morning xD
08.05.2020 16:17 # 10
No, my friend did not understand.
The screw may be loose, it will be like you are hanging somewhere when you open it. You will understand that you will install the door anyway.
08.05.2020 16:17 # 11
psychoabi
If you tighten the hinge parts from the bidet spray oils, you will avoid the problems caused by the problems and provide a more comfortable opening and closing.
08.05.2020 16:17 # 12
BurakGONULAL
now I have looked at the carpet on the field, looking at the hinges, it is going to be with a star screwdriver, it is not heat either :)
08.05.2020 16:17 # 13
MaximuS
[QUOTE = HuseyinTurk] no friend you don't understand.
The screw may be loosened, it will be as if it is stuck somewhere when you open it. You will understand that you will install the door. = ": # b8d1e0"> + 1 "Applause"
08.05.2020 16:17 # 14
ciha_n
The spray for squeaking works, certainly the same problem in our 307 was at the back door and the problem with the rust remover was resolved
