my display is broken help
08.05.2020 18:46 # 1
peugeotttt
hi friends.2000 model 206 gti, the indicator of my vehicle is broken. The tachometer and mileage indicator are not working.
08.05.2020 18:46 # 2
samet206
There is no need to buy a zero or a bounce indicator for these, if I misunderstand the situation. speed was not working, the speed was not obvious, the shower was running after the ground. km counter was not working.
08.05.2020 18:46 # 3
ahmed206
Even if my km counter stops, I'm comfortable, 122 thousand came from traveling a lot :)
08.05.2020 18:46 # 4
peugeotttt
I went electrician here, we can not do it, they are very sensitive.
08.05.2020 18:46 # 5
samet206
I think your electrician has squeezed so badly, there is no such a sensitive situation and there is no information about anyone who has a tendency to have electronics. I said for you, you prefer to buy a new one, you will pay a fee until it reaches the cistern, I hope you will handle it in a short time.
08.05.2020 18:46 # 6
Hackerzade
I have a brothers 2000 model dashboard, but roland garros is compatible. Let's see if the back of the instrument panel is yellow and white is double input.
08.05.2020 18:46 # 7
peugeotttt
Roland s panel is the same as the gti panel.
08.05.2020 18:46 # 8
abdullahk
When I bought the 2000 model 206 vehicle, the tachometer was shaking, the km showed missing. I couldn't find a master to make a repair. I said, let's do a 350 tl show on the master, I would do it myself if it was already a part. I did the following way easily. I would share the pictures to help, but the site was removed.
may not want it repaired for.
08.05.2020 18:46 # 9
abdullahk
The pin holding the damn green gear in the picture is broken because it is made very gentle. If you heat a batch needle and replace it nicely, it is stronger than the factory produces. You have to match the spring in the picture properly. Removing the panel is in google images. When you open it, pay attention to the digital km indicator strip.
08.05.2020 18:46 # 10
abdullahk
I will not share pictures. Write 206 indicator cark repair to the images.
abdullahk 2014-08-25 12:14:07
08.05.2020 18:46 # 11
abdullahk
1999 2004 analog km or cycle
It will be a source for friends whose indicator is broken. usually the transparent rod inside is breaking
previously someone else did and shared their pictures.I looked at them and disassembled the instrument panel.The parts that run the km and the tachometer are the same.the tiny motor and 2 gears. they did not knowingly make it durable. I broke the quilt needle in the place of the piece and heated it with a lighter.It was stronger than the factory did. using the navigation whether it is correct when inserting the needle
You can adjust it by looking at its speed. It wants milimetric workmanship. Carefully disassemble and take a quilt and a new dashboard to save you from peeling.
abdullahk 2014-08-25 12:46:15
08.05.2020 18:46 # 12
okan77
If you were in Istanbul, we would have made you point shot ... but when it is Tekirdag, things change. Also, the new dashboard may not work properly on the dashboard ... Synchronization needs to be done ... It is very difficult to insert the spring in the dismounting event.
08.05.2020 18:46 # 13
peugeotttt
If I am in Istanbul, I will not be able to do it anyway. We cannot have limited opportunities here. There is no intelligent master. My dealer was just in time.
08.05.2020 18:46 # 14
pierson
4 in km indicator on my instrument panel. the figure seems incomplete ... that is km 114850 but 4 digits seem to be missing..what might be .. is the leds underneath it.bitti
08.05.2020 18:46 # 15
peugeotttt
friends, my display was broken, I found it, I found it, but I bought it.
