my car stops at the first start in the morning
08.05.2020 17:13 # 1
deniz26
hello 206 1.4 automatic gearbox has been stopping in the mornings for the first 2-3 mornings. I try it a few times then it works fine after all day no problem just in the mornings I wonder what could be the problem. Meanwhile, I had my vehicle lpg 2 months ago
08.05.2020 17:13 # 2
Zagorka
& nbsp; The question is probably spark plug & nbsp; & Nbsp; Cente 2012-12-19 15:34:29
08.05.2020 17:13 # 3
deniz26
the vehicle runs on the first gasoline, after 100 meters or so, it switches to automatic gas
08.05.2020 17:13 # 4
Zagorka
Try Running the Anthem for 5 - 6 Seconds at a Time & nbsp;
08.05.2020 17:13 # 5
deniz26
unfortunately, it is not working. 5-6 times after trying it, it is lightly kicking.
08.05.2020 17:13 # 6
Zagorka
The Problem Is Just Started If It Is From The Cold Weather In the morning it gets very cold so the engine oil may be freezing and not starting so there is not much solution for it :) & nbsp;
08.05.2020 17:13 # 7
dukenukem82
If it stops at the first start and stops when idling, this will repeat in the future even if it clears the throat butterfly. At the first start, give a little gas, shake and nothing will stop.
08.05.2020 17:13 # 8
deniz26
Yes, he takes the first starter and stops when he is ready to work. Let me have such a problem if my fear starts to stop when it is cruising: > 2012-12-19 16:06:36
08.05.2020 17:13 # 9
deniz26
[QUOTE = Cente] The Problem Is Just From Cold Weather If It Just Started It is getting very cold in the morning so your engine oil may be freezing and not starting so there isn't much solution for it :) & nbsp; [/ QUOTE]
I guess today I think my car is leaking oil There was an accumulation of oil where I parked. Could there be a problem from this
08.05.2020 17:13 # 10
Zagorka
I wouldn't know this:) & nbsp;
08.05.2020 17:13 # 11
soneroo
working in the mornings is a problem that arises in cold weather, and the solution is simple. When it comes to the misfire problem, there are two reasons for this, there are problems with the spark plugs or the fuel filter of your vehicle may be old, so the dirty gasoline passing through the filter may be causing the misfire problem. Reviews
08.05.2020 17:13 # 12
sarbasmurat
[QUOTE = deniz26] hello 206 1.4 automatic gearbox has been stopping at first start in the morning for 2-3 days. I try it a few times then it works fine after all day no problem just in the mornings I wonder what could be the problem. By the way, I had my vehicle fitted with LPG 2 months ago [/ QUOTE]
In my car, automatic transmission runs for a few minutes.
08.05.2020 17:13 # 13
cgty86
If the oil level is low, there is a possibility that it may work hard but if there is a problem in the first work in the morning, this is most likely a problem of ignition elements such as battery, spark plug coil.
08.05.2020 17:13 # 14
_ali_
Get some new gasoline in the tank and drive the vehicle for 1-2 days, that's how mine went.
