my car stops at the first start
08.05.2020 16:10 # 1
intermetin
Hello friends. I found a solution to my probes by writing
on this forum many times. Many thanks to everyone who contributed. & nbsp ;,
problem with my search: When I first started my car, it stopped once in a while, but this problem was not frequent. But when I started my car for the last week, it stopped. I have to waste it and root the gas. The problem goes away after taking a certain cycle. I asked a few people, they said it could be idle adjustment. because when I run, the cycle goes below 10 thousand. Do you, dear friends have any other suggestions?
08.05.2020 16:10 # 2
intermetin
by the way my car is 206 sedan
08.05.2020 16:10 # 3
metin
[QUOTE = intermetin] meanwhile my car 206 sedan [/ QUOTE]
& nbsp;
if you wrote this in detail in your signature, you understand it engine oil petrol lpg diesel etc equipment.
08.05.2020 16:10 # 4
fexzi
Is LPG kit available?
08.05.2020 16:10 # 5
intermetin
car 2008 model peugeot sedan 1.4 lpgli
08.05.2020 16:10 # 6
AliOzagan
I had a problem like this. If you don't let the gas start at idle for the first time, the throttle was opened for cleaning. There was a part in it. There was a break in it. We changed it. When the throttle was cleaned, the problem disappeared.
08.05.2020 16:10 # 7
mon
Does it stop again when it runs directly at lpg?
08.05.2020 16:10 # 8
intermetin
YEAH. THESE LPG LISTERS ALREADY WORKED ON GASOLINE AND PASSED AFTER A SPECIFIC TRANSFER, I DID HEARED THAT,
08.05.2020 16:10 # 9
fexzi
Your vehicle stops in this way due to the LPG mixer or the programming in its brain, the new generation sequential system LPGs can do this because the program does not hold, unfortunately.
I hope that this problem will disappear in a short time, pleasant forums.
08.05.2020 16:10 # 10
Ako06
the problem is probably LPG related. As they say, it may be in the throttle.
08.05.2020 16:10 # 11
emrnl
my friend had the same problem, I cleaned the throttle again, did not notice anything.Then I used my car for 1 week only in line with the information that I got from a master, the problem was solved.
08.05.2020 16:10 # 12
It is normal to stop because the engine is cold in the first time, but if it sticks while it is hot, it means there is a problem in the vehicle.
08.05.2020 16:10 # 13
emrnl
When I asked, they said that the pressure of the pump may be low, which is likely to be the sub-industry (which I use the sub-industry because I burn it twice).
08.05.2020 16:10 # 14
dukenukem82
clean from injectors or replace if guaranteed.
08.05.2020 16:10 # 15
intermetin
do what you say friends & nbsp; I will go to the lpg master & nbsp; when the problem is solved, I inform you, my dear friends. Thank you very much for your interest.
08.05.2020 16:10 # 16
metin
We are waiting for your good news.
08.05.2020 16:10 # 17
intermetin
hi guys I text. yesterday I took the vehicle to the engine master. I had the computer connected and they said it was okay. I buy gas and gas from different stations. They said it could be from that. They advised me to use 20 liters of gasoline and additives and run them on gasoline until they were finished. I don't think there will be a solution, but I will try. I inform you, my dear friends, about the developments. of love ...
08.05.2020 16:10 # 18
I rarely experience a similar situation. My problem is caused by idling engine. Does the vehicle create the same problem when using only gasoline?
