my car's sports spring selection..please help ...
08.05.2020 14:07 # 1
"C hello 206 xt 110 hp 2001 model & nbsp; I have the vehicle.I have not been there for 3 months. How do I solve my problem without upgrading the car too ... I upload the pictures to the facebook..link:
< DIV> & nbsp;
08.05.2020 14:07 # 2
Orhan
Paint prog pictures of your vehicle. You can easily reduce the image by & nbsp; and upload it from http://img191.imageshack.us/ & nbsp; ..
08.05.2020 14:07 # 3
GokhaN
It is very difficult to solve that problem with 17 rims and the bigger the rim will take the front set very quickly. Unfortunately, in the hoods of the 206's, & nbsp; "C
08.05.2020 14:07 # 4
MirakGTI
You will take out the hoods completely, my friend.
08.05.2020 14:07 # 5
Aytac
In My Car & nbsp; Right And Left And I Swept Left And Also 185 55 14 Wheels Are Tread Ragmen..Surten Places Trace Is Clear In Hoods To Remove From Them.
08.05.2020 14:07 # 6
EminONAL
I had the same problem in 205 55 17. I made a full turn and screwed the hood upwards from where the tire was riding. It did not rub any more.
08.05.2020 14:07 # 7
I understand, but thank you, but my upgrade does not prevent it from hitting when it enters the pits. If I prevent it, what kind of spring should I use?
08.05.2020 14:07 # 8
Onur
it does not hit in the pits, but rubbing may still occur due to the tire size.
08.05.2020 14:07 # 9
MirakGTI
[QUOTE = buraksasa84] I understand, thank you, but my upgrade does not prevent it from hitting it when it enters the pits, what kind of spring should I use or if I cut the originals in my hand, would it increase a little ?? [/ QUOTE]
If you cut the originals, the vehicle will descend instead of low. Bowing is not a good thing. 3.5 cm spring will be enough or you will remove the hoods my friend
08.05.2020 14:07 # 10
As you said, when I go into the 3.5 cm bow pits, I hope you will avoid knocking .. I hope I get rid of this problem
08.05.2020 14:07 # 11
Aytac
Get rid of ins
08.05.2020 14:07 # 12
No, I wrote wrong, there is a sports bow right now but I do not know how a bow is in a length, but how should I change the pits hitting the hood .. please help .. Unhappy
08.05.2020 14:07 # 13
shamed
Aytaç 185 55 14 I think you also sports springs war, if I put 106 gti rims on my vehicle just like this, would I do rubbing etc.?
08.05.2020 14:07 # 14
Aytac
Of Springs Kac Cm?
08.05.2020 14:07 # 15
shamed
There is no spring or something, if I just put the gti rim
08.05.2020 14:07 # 16
Aytac
+ I Have Coilover ..
08.05.2020 14:07 # 17
shamed
If I do not install a spring on the vehicle, would it be 185-55-14 rubbing etc etc if I just put on the gti rim?
08.05.2020 14:07 # 18
Aytac
No way!
08.05.2020 14:07 # 19
shamed
OK, thank you, if you say there is no friction or something, it is ok.
08.05.2020 14:07 # 20
karayel1984
Greetings, friends, I got my car 2nd hand, there are sports springs, but I don't know how I can know how to learn. karayel1984 2010-04-24 17:59:20
Page : / 2
