My car's right glass and right mirror don't work |
| 08.05.2020 17:42 | # 1 |
| 08.05.2020 17:42 | # 2 |
tlp |
You can easily find the insurance scheme of 307 from the internet You can easily find out which insurance / number functions in the scheme. You will already see from the fuse, the copper part will be broken All you have to do is install a new fuse of the same value In this way, you can tell if the component that is not working is from insurance. He did not come to the electrician's job or said it for money I think it's probably from the insurance I think it would be useful to benefit from the insurance scheme |
| 08.05.2020 17:42 | # 3 |
Don't let anyone who says I am an electrician in your car, I don't know anyone who says I don't know, go and find an electrician who knows this tool. Go to an electrician after getting the opinions of the helpful and helpful friends, describe it and make it .... I think it is a problem that can be solved by changing insurance! The reason for the blow of the fuse should be investigated, is there a short circuit in the cables entering the door? Is the glass motor, mirror motor etc. overloaded and fuse blown? Going to the electricians who do not know their vehicle, rush them step by step.
| 08.05.2020 17:42 | # 4 |
user manuals and fuse box information for all pugs ... |
| 08.05.2020 17:42 | # 5 |
There is a problem with wiring, since the electronic hardware on the right door is not working. The door face should be inserted and checked and also the cable socket between the door and the pole should be checked. If there is a problem with insurance, all windows and mirrors will be disabled.
| 08.05.2020 17:42 | # 6 |
IT WILL BE CHANGED FROM THE CONTROL PANEL IF IT DOES NOT HAVE A REPORT TO BE REPAIRED. |
| 08.05.2020 17:42 | # 7 |
Thank you very much for the information you provide. first of all I asked him if he was a model that the right electrician you are saying was foreign. my door locks as a central lock, there is no problem, glass mirror and heat indicator do not work tomorrow my first job will be looking at the fuses thank you for your interest and interest.
| 08.05.2020 17:42 | # 8 |
I looked at the fuse box, there is one fuse, when I remove it, the automatic of all the doors are canceled. I could not remove the door on the right side, but I saw that the cables were plugged and could not be removed.
