my car pulls left and right ...
08.05.2020 17:32 # 1
ADANALI_01
netseer_tag_id = "15360"; netseer_ad_width = "1000"; netseer_ad_height = "40"; netseer_task = "name"; netseer_imp_type = "1"; netseer_imp_src = "2"; <= "http://cl.netseer.com/dsatserving2/setseerads.js" = "text /">
when my friends are on the road with my vehicle, when I get on the gas or when I pull my feet out of the gas or when I press the fireplace, my car pulls to the left and right. I wonder what is the reason for this? Anybody encountering the same fault ...
08.05.2020 17:32 # 2
samet206
Make the balance adjustment of the rod adjustment. The wheels may not have the balance adjustment. This is another situation that comes to my mind as a surface. It is not like this one.
08.05.2020 17:32 # 3
salihata
If your tires are old, they will pull them, even if they are not worn, the tires have a lifetime. See him, the date of manufacture on the tires.
08.05.2020 17:32 # 4
ADANALI_01
MY TIRES NEW MORE 2012 6 MONTH TIRES ...
08.05.2020 17:32 # 5
peugeotttt
Also check the tire air. If it is not from the tires, the most likely is from the rod settings.
08.05.2020 17:32 # 6
ADANALI_01
friends solved the problem, I changed one of the swings, the master said the other was solid, he said no need to change it ... now we changed it on the other table like cillop, thank god I'm not afraid to press ... thank you all ...
