My Car Keeps Stopping
08.04.2023 19:32 # 1
Volkan66
Hello, I have 1997 Model 106 Xr Vehicle.
The problem of my vehicle:
My car keeps stalling.
The car stalls directly when I don't press the gas.
I Bought a New Idle Engine, Installed It Myself and cleaned the Throttle.
I couldn't get a result.
If anyone knows about this, please help.
09.04.2023 04:47 # 2
Circassian
How about the map sensor?
09.04.2023 04:50 # 3
Volkan66
My teacher stops at gas.
10.04.2023 20:00 # 4
Circassian
I guess there is no mechanical problem.
Try to find the problem in this direction due to sensors and sensors.
You should start with the simple first
03.10.2024 11:08 # 5
106xr98
Hello, did you solve the problem? I have a 160 xr 98 model Peugeot, and the car stalls on both gas and petrol. I've had everything done, including injectors, MAP sensor, idle, timing adjustment, spark plug replacement, throttle body cleaning, but it's not working. Can anyone help?
23.02.2025 17:48 # 6
AlperM
Hi, I have the same make and model car. I had a similar problem. They said the valves needed to be adjusted because it was reconditioned, so I had that done, and then it stopped. It might be helpful to have it checked.
