my car is very yakiyo
08.05.2020 14:07 # 1
yeniceri06
Hi friends, I will have a question for you, I have 206 1.4 l vehicle, I filled the car, 100 km half of the tank, I spent gas, I do not press the car, I use it in high gear.
08.05.2020 14:07 # 2
Onur
Definitely not normal but semi-tank car at 100 km automatic?
08.05.2020 14:07 # 3
haruncoskun
I think there may be a problem in the display, after completing 100 km after completing, do not be full again then it will be clear.
08.05.2020 14:07 # 4
ErkanKurnaz
[QUOTE = yeniceri06] hi friends, I have a question for you, I have 206 1.4 l vehicle, I have loaded the car, I have 100 km, half the tank, I have spent gas, I do not press the car, I use it in high gear.
Look, what is that daddy 8 cylinder this car? but 206 fuel misers are known
08.05.2020 14:07 # 5
yeniceri06
bro, it looks like i have a nissan skyline in gold, it doesn't even burn so much I don't even understand what the 1 .4 engine malfunction could be.
08.05.2020 14:07 # 6
Murat
No way. The bottom gas does not burn again. There's probably something wrong. The indicator is likely to be broken.
08.05.2020 14:07 # 7
Onur
I have a automatics, I burn 10 liters in congested traffic.
08.05.2020 14:07 # 8
GokhaN
there may be a problem in the display, there may be a hole in the warehouse Wink
08.05.2020 14:07 # 9
arifkemal
I don't know how many models but when I bought it, 206 burned 50 krş, anyway I had maintenance engine or something, engine gasket rotted, radiator or something changed, returned to normal. maybe that kind of thing.
08.05.2020 14:07 # 10
HakanGokdemir
[QUOTE = haruncoskun] there may be a problem in the display, I think after completing 100 km after completing, do not get full again then it will be clear [/ QUOTE]
Harun, who has not left anything else to say, we must first understand whether the problem is in the indicator or not.
08.05.2020 14:07 # 11
yzt06
the problem is 99% needle .. even if engine failure, it can not burn so much.
08.05.2020 14:07 # 12
yeniceri06
Your vehicle was as good as I said before, without the 2003 model vehicle.
08.05.2020 14:07 # 13
t@lip
Either the indicator is faulty or the bore hole ..
08.05.2020 14:07 # 14
yeniceri06
friends, I check on the way while I am on the road, according to the distance I go, the needle is falling slowly.
