MY CAR IS TAKING WATER .. WHERE OR WHERE? Help please
08.05.2020 17:23 # 1
hLL
My car is getting water in rainy weather. the only part I see juicy is the bottom part of the right back seat, the base on which we put our feet. Only that carpet is wet. right back floor carpet: S there is no wetness in other places, but it's always wet. Please help. I looked down and the car has a couple of holes, but I know what. Is he entering from there? I asked a few people. Pejo said buy it from the dealer and put it in those holes. He said he was entering from there. I share photos in the first opportunity.
Sorry for spelling mistakes, I am writing with a foreign keyboard. Thanks for the answers.
08.05.2020 17:23 # 2
KenBlockJR
usually takes from suppositories
08.05.2020 17:23 # 3
Bugra
We had friends who had similar problems before, opened a thread in the forum and solved the problem in various ways. If you search, you will find it. Also, when you remove the door wicks, the glass wick and the interior trim of the door, the insulation material may be visible and its lower part may be opened. If you check them and change them, your question will be solved. respects .. & nbsp;
08.05.2020 17:23 # 4
elestern
Hodja, if you solve this problem, would you let me know?
08.05.2020 17:23 # 5
gngburak
I have the same problem, the rain, the driver's side, 3 finger water is accumulating, I did not understand, I could not solve the problem
08.05.2020 17:23 # 6
fxmen
I have some suggestions for those who have experienced this problem, first of all, there are holes in the bottom of the door. The casters in the hose that hurts to the kettle are hurting and running away.
08.05.2020 17:23 # 7
hLL
I will try what you say thank you guys .. my problem still continues :(
08.05.2020 17:23 # 8
hLL
I bought bituminous insulation material from a master, I hope I will apply it to the holes in the bottom. When I apply it, I will share it if it works. Thanks Reviews
08.05.2020 17:23 # 9
elestern
don't forget to photograph
08.05.2020 17:23 # 10
leffe
I had the same trouble for the first time recently. it was raining a lot and when i raised the mop i saw the underlying floor got wet. the heater core looks dry. I didn't understand why?
08.05.2020 17:23 # 11
[QUOTE = KenBlockJR] usually takes from suppositories [/ QUOTE]
Thank you. It turned out as you said. I noticed that it entered the tiny rip in the wick. My problem is solved.
08.05.2020 17:23 # 12
samet206
We could handle door tires and we had it done.
08.05.2020 17:23 # 13
nupel307
I had 307 before I lived, probably going through the range of the taillight water. I siloed it before it passed.
08.05.2020 17:23 # 14
There was a similar problem, there was a clio when I got into the car, there was wetness in the viset section there. If I have an antenna, if I get water from there, then I would have shut it down.
08.05.2020 17:23 # 15
rakasan
My friend has a sunroof in the vehicle?
08.05.2020 17:23 # 16
pierson
What is the place where you call the door wick ... where is the glass wick..the right back side is also getting water .. I say if I change those wicks ..
08.05.2020 17:23 # 17
pierson
guncel
