My car is singing
08.05.2020 17:05 # 1
FeverDog
Friends had done this to me before, but yesterday I was worried when I did it several times in a row; When I first climbed a ramp - which was high speed, I was going fast - suddenly the gas was cut off (without pulling my foot out of the gas). Then when I started on the straight path, he made the same movement several times in a row. and now he does it once in a while. I had maintenance done last week, oil change was made with air oil and diesel filters. I took my fuel from its usual place (opet). what's the problem?
08.05.2020 17:05 # 2
caster21
The same problem we had in our car, the induction coil changed, it also started to misfire and the fuel consumption decreased.
08.05.2020 17:05 # 3
Peugeot306
98% ignition coil 2% spark plugs & amp; spark plug cables.
I know the original of the ignition coil is 150-200 TL Yan Sanayii 40-60.
08.05.2020 17:05 # 4
berk2309
only car no spark plug :) can be from injectors gas sensor position sensor idle valve & nbsp;
08.05.2020 17:05 # 5
berk2309
was there any problem before bode care?
08.05.2020 17:05 # 6
Peugeot306
[QUOTE = berk2309] lonely car no spark plug :) can be from injectors position sensor of the accelerator pedal idle valve & nbsp; [/ QUOTE]
You are right I did not see it in the signature section (= & nbsp;
08.05.2020 17:05 # 7
blacke4gle
The brothers are doing the same misfire problem in the gas on my vehicle. Let's see what I will get to the industry tomorrow. If you have it checked, of course: /
08.05.2020 17:05 # 8
FeverDog
I haven't made it look yet, but I came to the conclusion that I don't know right or wrong, When I first start the vehicle, I wait 2-3 minutes at idle, then move and use high speed, there is no such problem. he did this 1-2 times before maintenance. but I have been using it for 2 days as I said, it has not been repeated. What did they say in the industry, brother?
08.05.2020 17:05 # 9
berk2309
I think it is from the idle valve if the speed is not high
