My car is shaking
08.05.2020 16:36 # 1
mucahidyasar34
Right friends new member you can help 2002 model quiksilver I have my car going to 1.5 revolutions without stopping the titry gas at the gas station. Previously, the gasket was burned, they said, I made it, the gasket was renewed, the circuit was renewed, the thermostat was renewed, the water did not decrease, I just changed the oil, but I could not understand the car still shaking where it stopped. I would appreciate it if you can help, respect ..
08.05.2020 16:36 # 2
fTh206
Maybe it is from the Lpg setting & nbsp;
08.05.2020 16:36 # 3
Have you checked your spark plugs?
08.05.2020 16:36 # 4
mucahidyasar34
How many times I got into the setting, I made it dropped. Spark plugs replaced injectors completely & nbsp;
08.05.2020 16:36 # 5
3saniye
[QUOTE = mucahidyasar34] Right friends, new member, you can help, I have a 2002 model quiksilver. Previously, the gasket was burned, they said, I made it, the gasket was renewed, the circuit was renewed, the thermostat was renewed, the water did not decrease, I just changed the oil, but I could not understand the car still shaking where it stopped. I would appreciate it if you can help .. Best regards. They said spark plugs and ignition coils. We changed it, they did not improve. They said it could be battery. They did not have room. They said LPG. . Let's see what happens now.
08.05.2020 16:36 # 6
Everything Could Happen ...
08.05.2020 16:36 # 7
GiTaRRa
++ I have just started too, I guess what might be the lpg setting. But I don't think it is a gearbox, I have to ask & nbsp;
08.05.2020 16:36 # 8
djchaos
rpm may rise from throttle to idle sensor disassemble throttle and clear to idle sensor
08.05.2020 16:36 # 9
okankrgz
Check for the following if there is flickering with rotational malfunction, idling sensor and cables, throttle clean fully open, intake manifold cleaning, idling adjustment
08.05.2020 16:36 # 10
mucahidyasar34
Thank you guys, thank you very much gram tremor in the car. Idle sensor, throttle, intake manifold, all of them bought contact spray (without oil), cleaned and fixed.
08.05.2020 16:36 # 11
okankrgz
your eyes are enlightened :)
08.05.2020 16:36 # 12
mucahidyasar34
Eyw brother, thank you :)
08.05.2020 16:36 # 13
syncgny
friends I'm thinking of buying 206 quiksilver from mrb. Can you help me a bit! Can you recommend?
