my car is not working (Problem solved)
08.05.2020 15:34 # 1
goktug
friends I tried to start the car again from where I parked in the morning did not work. There was no problem before ... I press it after the glow plug light goes out, no starter. only the indicator lights are off. There is no forcing sound that looks like a dead battery, tape is working, the headlights are on ... there is fuel. It rained all day long. Could water escape any place here? what are your thoughts?
(problem solved friends. the problem was the loosening of the starter cable. thank goodness i solved the event. thank you to the friends who helped ...)
göktuğ 2011-06-09 14:32:01
08.05.2020 15:34 # 2
pug♥lovers
teacher, clean the battery's poles with sandpaper just as you told me.
08.05.2020 15:34 # 3
goktug
Thank you bro. So you say it originates from the battery. but all battery related equipment is working in the car. And when I start, there is no sound, it's not a battery misfire. I know that shooting is also harmful ....
08.05.2020 15:34 # 4
sedatdatse
I agree with your grandfather because the first mars instantly draws a very high current
If the battery terminal oxidation occurs, it will not leak current.
In the evening, it works because there is no high current
if you do contact tipping and sanding
08.05.2020 15:34 # 5
goktug
I tried to run it again now. It happened. This time he wrote economy mode active very quickly. As you said, I think it originates from the battery. Or the battery is weak since I try to run it in a row?
08.05.2020 15:34 # 6
berk2309
try to start with a reinforcement, don't knock, but if you can only borrow a reinforcement or battery, plug it in and try it
08.05.2020 15:34 # 7
goktug
Okay, tomorrow I will focus on the battery first. I hope the battery is ...
08.05.2020 15:34 # 8
berk2309
construct. As the friends say, battery is not my brother, no more starter engine can come out, as soon as it is clear, the answer writers in more experienced members see the subject
08.05.2020 15:34 # 9
goktug
I hope the battery is friends. Though there is a motor vehicle but still, I hope there will be a small breakdown.
08.05.2020 15:34 # 10
oguzhan29
Hope it is good bro, I hope there is no big problem but it seems like a battery
08.05.2020 15:34 # 11
goktug
Thank you, Oğuzhan. I did not think of the battery at first, then when I say economy mode active, I said 90 percent battery. I had opened the cd player for a while before I started the car.
08.05.2020 15:34 # 12
-ayhan-
If you changed the battery of the key or something, you may have dropped the chip inside the key, then it will not work, the same thing happened to me, the watchmaker dropped the chip while replacing the battery, I pulled the car into the industry, they did not find the hours of failure in the industry, they eventually came to their minds and resolved;)
08.05.2020 15:34 # 13
goktug
I did not change the sibling battery or something, but the remote button for the ignition was dropped from there. If the chip fell, it fell from there, as you said. But the contact turns, the accessory position comes to the starter position on the line, I turn it, it does not get a starter ...
08.05.2020 15:34 # 14
-ayhan-
If you have a spare key, try to run with it as well
08.05.2020 15:34 # 15
pug♥lovers
If the battery is depleted or not, it does so.
First I thought the battery was not empty or the battery wasn't charging, but I thought the problem was very simple.
08.05.2020 15:34 # 16
goktug
I tried it with a spare key.
08.05.2020 15:34 # 17
-ayhan-
I hope it is nothing important bro, sorry, I do not understand enough to make another guess, unfortunately
08.05.2020 15:34 # 18
goktug
Thank you brother.
08.05.2020 15:34 # 19
berk2309
Isn't there any friend or something that you can come with right now with your car :)
08.05.2020 15:34 # 20
goktug
A friend who is happy, his battery is different. That's why I say I am in the eyes with daylight. I disassembled the poles and put them on. I think there is no oxidation finished ...
Page : / 3
