my car is not working please help
08.05.2020 18:00 # 1
emred
Hello friends, I have 206 gts, I washed the car in the last oil. I hit the car again, it did not work, there was also gasoline in it. I couldn't show it to the master. I would appreciate it if anyone who has experienced the same situations or is knowledgeable helps.
08.05.2020 18:00 # 2
berk2309
Do you have an ignition? Do you come? If you are holding water in the engine, you may have damaged the coil.
08.05.2020 18:00 # 3
rifatseker
Have a look at the gas pump.
08.05.2020 18:00 # 4
emred
teacher, I guess the car is not firing, I guess I tried to shoot it, but it still didn't. the vehicle is smothering, but it doesn't work
08.05.2020 18:00 # 5
error
petrol can be a problem, dirty gasoline etc.
08.05.2020 18:00 # 6
TuNeR_32
one of my friends had washed the 106 gti engine, the hood waited in the sun for 3 days open then it had worked.
08.05.2020 18:00 # 7
berk2309
If there is no ignition, see the spark plug of these bobs, remove them, dry them, clean them.
08.05.2020 18:00 # 8
Aziz
Finding the solution that will be very difficult, but if it happened after washing and washing the engine, you can not get out of this way. even if it is not related to washing, it may have accidentally caught the degradation in the gas pump, or you may have come across a different fault (immobilizer etc.) Ouch
